We have a ColdFusion 10 Standard server out in production on an IIS 7.5 Windows 2008 R2 Datacenter virtualized environment. Randomly throughout the week, requesting our page will result in a blank white page (viewing source shows absolutely nothing).
I remoted into our server and noted that coldfusion.exe was taking up 730MB. I don't track these things so I don't know if that's a lot or not. And usually restarting the service takes 15-20 seconds. This time it took 20 seconds to stop the service and about 30 to start it.
I am not familiar with which logs to check in order to provide some useful information, but if anyone has an idea of where to send me looking, it would be greatly appreciated.
Hi Aegis,
What is CF10 update level? Has isapi_redirect.dll been updated either manually or with WSCONFIG tool?
Does CF10\cfusion\logs\coldfusion-out.log or CF10\config\wsconfig\N\isapi_redirect.log report any errors or warnings?
That should get you started, Carl.
Update 11. I've updated the isapi_redirect.dll manually.
I'm not at work at the moment, but I'll get back to you on those error logs. I know for a fact that there are a TON of errors for the coldfusion-error.log file, but I'l check the ones you specified and get back with you on what errors messages are there. We learned of the white page issue at 3PM EST today, I'll check around that time for errors.
OK, here's some of the coldfusion-out.log file around the time we discovered CF was rendering white pages: I bolded areas of interest.
Oct 15, 2013 12:31:25 PM Error [ajp-bio-8012-exec-134] - File not found: [path]/ajax.cfm The specific sequence of files included or processed is: \\[path]\ajax.cfm''
Oct 15, 2013 12:31:25 PM Error [ajp-bio-8012-exec-121] - File not found: [path]/ajax.cfm The specific sequence of files included or processed is: \\[path]\ajax.cfm''
Oct 15, 2013 13:08:10 PM Information [scheduler-0] - Run Client Storage Purge
Oct 15, 2013 14:15:10 PM Information [scheduler-1] - Run Client Storage Purge
Oct 15, 2013 15:00:00 PM Information [DefaultQuartzScheduler_Worker-2] - Task default.Public FTP Purger triggered.
Oct 15, 2013 15:00:00 PM Information [DefaultQuartzScheduler_Worker-2] - Starting HTTP request {URL='http://[server-name]:80/[path]/index.cfm', method='get'}
<GroupWise WebAccess> WebAccess Servlet is shutting down
Oct 15, 2013 15:00:27 PM Information [pool-2-thread-2] - ColdFusion stopped
10/15 15:00:54 INFO License Service: Flex 1.5 CF Edition enabled
10/15 15:00:54 INFO Starting Flex 1.5 CF Edition
Oct 15, 2013 15:00:55 PM Information [pool-2-thread-1] - Starting logging...
Oct 15, 2013 15:00:55 PM Information [pool-2-thread-1] - Starting license...
Oct 15, 2013 15:00:57 PM Information [pool-2-thread-1] - Standard Edition enabled
Oct 15, 2013 15:00:57 PM Information [pool-2-thread-1] - Starting crypto...
Oct 15, 2013 15:00:57 PM Information [pool-2-thread-1] - Starting security...
Oct 15, 2013 15:00:58 PM Information [pool-2-thread-1] - Starting scheduler...
Oct 15, 2013 15:00:58 PM Information [pool-2-thread-1] - Starting WatchService...
Oct 15, 2013 15:00:58 PM Information [pool-2-thread-1] - Starting debugging...
Oct 15, 2013 15:00:58 PM Information [pool-2-thread-1] - Starting sql...
Oct 15, 2013 15:00:59 PM Information [pool-2-thread-1] - Pool Manager Started
Oct 15, 2013 15:00:59 PM Information [pool-2-thread-1] - Starting mail...
Oct 15, 2013 15:00:59 PM Information [pool-2-thread-1] - Starting runtime...
Oct 15, 2013 15:01:01 PM Information [pool-2-thread-1] - CORBA Configuration not enabled
Oct 15, 2013 15:01:01 PM Information [pool-2-thread-1] - Starting cron...
Oct 15, 2013 15:01:02 PM Information [pool-2-thread-1] - Starting registry...
Oct 15, 2013 15:01:02 PM Information [DefaultQuartzScheduler_QuartzSchedulerThread] - Task default.Public FTP Purger misfired.
Oct 15, 2013 15:01:02 PM Information [pool-2-thread-1] - Starting client...
Oct 15, 2013 15:01:02 PM Information [pool-2-thread-1] - Starting xmlrpc...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting jaxrs...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting graphing...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting solr...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting archive...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting document...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting eventgateway...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Event Gateway Disabled.
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting FlexAssembler...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting .NET...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting Monitoring...
Oct 15, 2013 15:01:03 PM Information [pool-2-thread-1] - Starting WebSocket...
Oct 15, 2013 15:01:04 PM Information [Thread-6] - Same Serial Number found on another ColdFusion server.The server may be out of compliance.
Oct 15, 2013 15:01:06 PM Information [pool-2-thread-1] - WebSocket server listens on port: 8575
Oct 15, 2013 15:01:06 PM Information [pool-2-thread-1] - ColdFusion started
Oct 15, 2013 15:01:06 PM Information [pool-2-thread-1] - ColdFusion: application services are now available
10/15 15:01:06 INFO Macromedia Flex Build: 87315.134646
Novell GroupWise WebAccess
Version 8.0.2
(C) Copyright 1993-2010 Novell, Inc. All rights reserved.
<GroupWise WebAccess> WebAccess Servlet is ready for work
Oct 15, 2013 15:02:41 PM Error [ajp-bio-8012-exec-3] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-26] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-6] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-38] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-30] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-39] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-2] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:42 PM Error [ajp-bio-8012-exec-11] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is:[path]\index.cfm, line: 409
Oct 15, 2013 15:02:41 PM Error [ajp-bio-8012-exec-13] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:43 PM Error [ajp-bio-8012-exec-18] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:43 PM Error [ajp-bio-8012-exec-28] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:02:43 PM Error [ajp-bio-8012-exec-25] - The request has exceeded the allowable time limit Tag: cfoutput The specific sequence of files included or processed is: [path]\index.cfm, line: 409
Oct 15, 2013 15:13:33 PM Information [ajp-bio-8012-exec-66] - Session rotated successfully.
Oct 15, 2013 15:13:33 PM Information [ajp-bio-8012-exec-66] - User admin logged in.
Oct 15, 2013 15:13:36 PM Information [ajp-bio-8012-exec-66] - Starting HTTP request {URL='http://www.adobe.com:80/go/coldfusion-updates', method='get'}
Oct 15, 2013 15:13:37 PM Information [ajp-bio-8012-exec-66] - HTTP request completed {Status Code=200 ,Time taken=854 ms}
Oct 15, 2013 15:15:56 PM Information [ajp-bio-8012-exec-66] - Session rotated successfully.
Oct 15, 2013 15:15:56 PM Information [ajp-bio-8012-exec-66] - User admin logged in.
We have Groupwise WebAccess on this server (Novell's web-based email web application). It seemed to terminate around 3PM, and CF followed shortly thereafter. Not sure why a task "misfired". As for the dual-license keys, our key was registered for 2 servers (our public web server, which is this log file, and our private intranet server). So I think that's just a false positive.
Not used Groupwise WebAccess myself so do not know. 3PM CF terminated, well that does not look good. Think "misfired" task and license warning are nothing to worry.
Could Groupwise WebAccess stopping bring CF down? Where I have CF configured to email through MSExchange stopping MSExchange/SMTP does not overly effect CF except for CF failing to spool email not halt CF entirely. If you schedule Groupwise WebAccess shutdown does CF stop?
Well, on the face of it, CF10 and GW WebAccess do not work with one another due to a problem with them both wanting to hard-coded-ly use the jakarta folder, however both make use of different isapi_rewrite.dll files.
We contacted Novell and their tech was gracious enough to take a look at this and actually modified some CF worker files to "integrate" GW with CF, so they both are using the jakarta folder that CF is (seems GW was using a built in Tomcat 5.x server and CF 10 uses a 7.x version)
So maybe because of this, GW has the ability to stop CF if it encounters and issue?
