I believe I have found a bug in the CFCHART fix for
Cumulative HotFix 2 (
http://www.adobe.com/go/kb400996)
I have the following CFCHART call which works w/o the patch
installed:
<cfset colors
="ff0000,00ff00,0000ff,ffff00,ff00ff,00ffff,ffcc00,ff00cc,f0ccf0,ccff00,cc00ff">
<cfchart showlegend="no" format="flash"
tipstyle="mouseover" rotated="yes" show3d="yes"
backgroundcolor="ffffff">
<cfchartseries type="pie" query="qryGetResults"
valuecolumn="numresp" itemcolumn="answerds"
colorlist="#colors#">
</cfchart>
However when I run the page with the hotfix installed it
fails with a Null Pointer Exception and indicates the the
cfchartseries call is the line in question. It does this whether I
specify the colorlist attribute or not. The query is not failing in
either case, so I am pretty sure that the changes to CFCHART in the
hotfix are causing the issue.
I am not sure how to submit a formal bug to Adobe, but
figured at least this is a good start.
