Tab between 2 cross references.
Oct 24, 2013 Oct 24, 2013
Hello,
I have an issue with the Framemaker coss refernces. When adding a cross reference like one that shows "Chapter no." and "page no." it is displayed with a tab between Chapter and Page eg. Chapter 3      on page 34.
I haven't figured out how to replace the tab with a single space or how to edit the tab size. I looked into the Adobe help and the online forum but haven't found an answer.
Best regards
1.3K
In the cross-reference definition, any tab in the construct would be visible as a "\t", and in the body text as a ">" (with text symbol display enabled).
Since Chapter Number is a system variable, there's some chance it's been modified to include a tab, which would appear similarly.
Change the "\t" to a space or non-breaking space ("\ ") as desired.
What the tab does is controlled by the Basic:Tab Stops properties of the paragraph in which the xref is inserted. In general, you don't want tabs in these sorts of Xrefs.
Hello again,
Thank you for your replay. Unfortunately no \t is visible in  the construct.
I'll attach a screenshot.
Check the construction of variables AbsNum and SeiteNum as well.
Would you be so kind to elaborate where I can look into  those default variables? When looking in to "variables" I find only costum ones and none auf the default.
I worked my way though the adobe help.pdf but didnt find anything helpful so far.
Best regards
> ... where I can look into  those default variables?
This presumes FM is in English UI mode:
  1. Click in some Body text.
  2. Special > Variable
  3. Select any System variable, such as "Chapter Number"
    [ Edit Definitions ]
  4. This particular variable is normally Definition:
    <$chapnum>
    Based on what you are seeing, it might be:
    <$chapnum>\t
  5. Delete the \t.
    [ Edit ]
    [ Done ]
If this is your situation, find the person who did that, and toss them into the North Sea, in winter.
When you edit a User Variable, the dialog only shows User Variables.
When you edit a System variable, the dialog only show System Variables.
I just tested this (with text symbols shown). A tab in a cross-reference
definition is not visible, if it is pasted as tab. If it is pasted as \t, I see
it as \t in the cross-reference definition and as > in the cross-reference.
Therefore I suggest to replace the characters between the number
and "on page" with a single space. Possibly a tab is hidden there.
Best regards
Winfried
While it's difficult to troubleshoot in (what looks to me like) German, I believe you are using the equivalent of the <$paranum> building block, which is picking up the tab from your paragraph's autonumber format. Replace that building block with the (German?) equivalent of the <$paranumonly> building block, and you should be fine.
Explanations for these things are in my (hefty, 700 page) book.
-Matt
Matt R. Sullivan
co-author Publishing Fundamentals: Unstructured FrameMaker 11
That did the trick. Thank you very much Mr. Sullivan. The paranum is the <$AbsNumExkl> in the German version of Framemaker 11.
But still, I believe the author of the document I am working on somehow tempered with the <$paranum> variable.
I would also like to thank every one else  who came up with a possible solutions to my problem.
Best regards
Mr. Lassen
Oct 25, 2013 Oct 25, 2013
Hmmm, If you want to see the default definition of the <$paranum> (<AbsNum>?) variable, simply create a new blank portrait document. Use that string to redefine your "problem" variable.
-Matt
