copying vector shapes from illustrator to fireworks
Sep 08, 2013 Sep 08, 2013
I've been having an issue with Adobe CC Fireworks. Every time I try to copy a vector shape or an image from illustrator and paste it to fireworks, I get this error: " Alert can't open the illustration". I am running OS 10.8.4. Has anyone else experienced this issue? Thanks in advance.
13.2K
Advisor ,
The following post offers a workaround/fix for Fireworks CS6 users having trouble opening or importing Illustrator files on the Windows 7 platform. I'm not sure if this applies to you or not:
http://blogs.adobe.com/fireworks/2012/08/workaround-for-illustrator-fi le-open-and-import-issue-in-f...
Sep 14, 2013 Sep 14, 2013
Thanks groove25, but I'm not even sure how I can uninstall Quicktime from my Mac, as Apple won't allow it.
More details on my issue: I tried installing CC on my iMac (before I was trying to get it to work on my newly purchsed MacBookPro), and I still get the same error. I've tried several times to reinstall it to but the bug won't go away. This pretty much renders fireworks useless to me, and that's a huge dissappointment considering how expensive it is.
Contributor ,
Oct 27, 2013 Oct 27, 2013
Hi
I also just updated Illustrator and can no longer copy paths from Ai to Fireworks. pretty useless apps now.
So I've discovered that it must be a clipboard issue in Illustrator. I can actually drag and drop (not copy paste for some reason) vector shapes from Illustrator to Fireworks several times before I get the dreaded error.  If I accidently press "command+ v" then I will get the error and not even be able to drag and drop any longer. In either case I have to exit out of Illustrator in order to get the popup with the "clear clipboard" checkmark, which I then have to select before restarting the program. I tried to find a way to clear clipboard in Illustrator without having to exit out of it, but had no luck. All of this is extremely frustrating, especially for the price that CC costs, but at least I'm able get it to work for a while.
Hope this helps and please let me know if you find any other solutions to this issue...
Contributor ,
Thanks for your reply.
I simply deleted CC and using CS6. I have done the same with other CC apps that simply do not offer anything new accept headaches and frustration.
Mar 17, 2014 Mar 17, 2014
I tried the drag and drop and it didn't work for me.
The only thing that worked was saving as EPS. Just remember to select the EPS version CS6 or earlier, because the EPS CC won't work either.
Mar 31, 2014 Mar 31, 2014
Save the illustrator file as Illustrator CS6 file, and then open it with fireworks, works perfectly
Jan 19, 2016 Jan 19, 2016
Thanks a lot, Trijulio. It worked perfectly.
Sep 09, 2014 Sep 09, 2014
Hi all,
I was having the very same issue. I simply LOVE Fireworks (during all my professional life, since the g'old Macromedia times haha) and I won't give up on it any time soon. Such a BIG SHAME Adobe discontinued this great software
Anyway, my point here is to sum up the alternatives friends above listed. It's working quite well for me using Fireworks and Illustrator at the same time whenever needed:
COPY and PASTE WON'T WORK so:
1- Try to click the wanted vector on Illustrator and drag to the Fireworks document (so you need to leave opened both windows somehow side by side);
OR
2- Save the vector you want to import into Fireworks as EPS (CS6 or below, NOT CC) then you simply import it in Fireworks;
OR
3- Save the whole Illustrator file as CS6 (or below) and then open it from Fireworks.
Cheers
Nov 06, 2014 Nov 06, 2014
For me it was an error that happened when going from Adobe Illustrator CC to Adobe Fireworks CS6. Since Fireworks isn't being supported right now it is stuck in version 6 until the foreseeable future. So if you will save your vector files in Adobe Illustrator CS6 or earlier version as an EPS file you should have no trouble importing these to Fireworks. This issue has been resolved for me. I'd love to hear back if you experienced something different. Mine works great now in the land of happy icon bliss. Cheers friends, M.
May 29, 2016 May 29, 2016
Another workaround for people with CC 2015 suite but not Illustrator 6;
1. copy and paste to Indesign
2. export as eps
3. this eps then opens in Fireworks for me
Thanks for everyone else's suggestions.
