Installed CF10 dev edition, wtih internal web server on my laptop and desktop. Both 64 bit win 7 and did the servery updates.
Laptop sees css file, while the desktop does not - same code base.
I have reinstalled CF10 on desktop, but it did not fix the problem.
Any ideas?
Sam.
It may be due to Directory permission issue with the user. Here in the below URL it is described how to solve it.
http://coldfusion-tip.blogspot.com/2013/10/you-do-not-have-permission-to-view-this.html
If your issue is something different then please see the HTTP response of your CSS page loading by using firebug then you will get more information about the issue.
I'm assuming this as a Windows / IIS / CF10 environment since it wasn't specified.
Clear the browser cache and then reload the resources. Is this actual CSS or is it LESS/SASS (if the latter, ensure the source code is 100% valid or the preprocessor can choose not to apply ANY styling)
Using Chrome's Inspector (F12) and check under the Network Tab (you may have to reload the page). Ensure that the .CSS file is returning a 200. If it's returning any other code, let us know what it is.
If you're using a toolbar, ensure that disabling of CSS styles is not enabled.
Upen - thanks I tried that but to no avail.
Aegis:
I did specify - and that i have the code base on two diffrent machines with diffrent results.
One works one does not.
AND I used the built in server so there is no IIS running on either machines (at least no IIS control panel i can find).
I put a simple html page in the root and it does not find it either, 404's.
It only seems to find cfm pages.
(reinstalled several times btw).
Help me understand here.
You do NOT have IIS, which knows how to process HTML files and serve them up. But you have installed CF as standalone (port 8500 by default). Now, to my knowledge, CF serves CF-related files. I don't know whether it's designed to handle HTML. So if you place a .cfm file and a .html file into its root and navigate out to both of them, CF usually only is invoked if the file extension is a .cfm file (It is an application server, not a web server). It would make sense that CF cannot "see" the index.html.
Now, I know this is about seeing a .CSS file, but I'm wondering if we're having in essence the same problem. You want the CSS file to be SERVED, but CF is just an application server, not a web server, CF could read the contents of the CSS file, but again, it's not a web server, I don't think it will serve the file to the browser.
For clarification, what do you mean by that a laptop "sees" the CSS file? It's one thing if you tell a browser to manually OPEN a HTML/CSS file and you direct it to the location of a file.
Also, what is the URL you are using to call this CSS file?
I have an application and on the laptop it reders the page with the styles listed in the css file.
On the desktop it does not. If I try to display the css file with
http://localhost:8500/filename.css it gives a 404 file not found.
The instalation was with the built in web server.
One thing I am going to try is to just copy the cf10 direcrtory from the laptop and replace the directory on the desktop.
If that does not work I will probably install appache and use that as the web server (it's what we do at work.)
And I am not saying I don't have ISS, I am saying that it does not show up in services.
Just to Confirm: When we are copying files into to web root of cf10 installation. Your css file directly under web root "C:\ColdFusion10\cfusion\wwwroot\filename.css" or
in "C:\ColdFusion10\cfusion\wwwroot\{Some Directory}\filename.css"
If second one is your case then you have to add your directory name in URL before file name:
Upen, in both cases 404. I tried moving the file around first - silly, I know.
Do you have the css file available on your Desktop at C:\ColdFusion10\cfusion\wwwroot\?
Can you create a test.cfm page. Paste the belwo code in it and save the file.
<cfoutput>This is a test CFM page</cfoutput>
Try to access the file http://localhost:8500/test.cfm and share the outcome.
Anit Kumar
Anit. CFM file created in C:\ColdFusion10\cfusion\wwwroot and viewable in http://Localhost:8500/test.cfm
Also a plain html file in root also viewable.
The CSS file in root - not viewable.
I Did copy the ColdFusion10 directory from the laptop to the desktop and no difference.
What I think I will have to do is setup Apache as the web server.
Is it possible for you to share the css and the file using the same.
Anit Kumar
I want to thank everyone for their help.
The problem was the mapping names. The internal server, tomcat, is case sensitive. So if the mapping is C:/ColdFusion10/cfusion/wwwroot/stringdae/ (/stringdae)
then the actual folder name better BE "stringdae" and not "stringDae".
