Hi.
I have a document where I would like to cross-reference paragraphs that have forced returns in them.
Unfortunatelly the returns are lost.
Any idea on how to accomplish this?
I am using unstructured FrameMaker 10.
Thank You
Peter
Use Text Insets instead of xrefs
Can a document text inset from itself (assuming that's the requirement here)?
If so, wouldn't the target text need to be in a unique Flow?
I'm thinkin' it might be easier to craft the original text as a variable, including hard returns ( \r ) as needed, then just use the var everywhere needed.
That would probably be even easier ;>)
I always teach xrefs, variables, and text insets back-to-back, as they're kinda related. Each would work to a degree, but it just depends on the size of the reused content.
For the TI, you could have the common text in a named flow on the reference page. The flow could be in the content doc, or in a separate doc containing one or more named flows.
Thank you.
That was a lot of new information.
I guess I have to read more about text insets, flows, reference pages etc.
My particular case is a large grammar of a programming lanuage that is listed as a complete grammar in its own chapter.
Fragments of that grammar is then repeated together with the description of specific language features.
I do not believe variables is the way to go as the grammar is formatted with both paragraph formats and character formats.
Ideally I also wish to have non-terminals cross-reference productions.
Can you recommend any books or websites that covers stuff like this.
The Adobe documentation mostly focuses on the Pods not on recommended use.
/Peter
You might want to also have a look at Steve Kubis' Auto-Text tool. See: http://www.siliconprairiesoftware.com/Products.html
This allows you to set up re-usable content snippets that are fully formatted.
@Peter: Well, since you asked...
I cover all of these in the 700 page book listed in my signature.
-Matt
Matt R. Sullivan
co-author Publishing Fundamentals: Unstructured FrameMaker 11
Text Insets work, as long as you don't need automatic Xrefs to a Glossary.
Suppose the first element in your grammar is the Abend keyword.
View > Reference Pages
View > Grid Lines
Special > Add Reference Page
Name: [ Syntax01 ]
[ Add ]
If the language is extensive, you are apt to need multiple Reference Pages.
From the graphics tool pod, select Text Frame tool.
Draw a suitably sized text frame on grid.
Graphics > Object Properties
Flow: Tag: [ Abend ]
[ Set ]
In the text frame, author and format your grammar for the Abend keyword.
View > Body Pages
At the desired insertion point in the narrative:
File > Import > File
{file self}
<*> Import by Reference
[ Import ]
Flow to Import:
<*> Reference page Flow [ Abend ]
Formatting of Imported Flow:
<*> Reformat Using Current ...
or
<*> Retain Source's Formatting
Updating of Imported Flow:
<*> Automatic
Repeat for remainder of grammar. Add new Syntax## Ref Pages as existing ones fill up.
Not an issue. It turns out that named flows can exist on Body pages too. You can create a text frame in an ancored frame, for example, and give it a unique Flow name.
This would allow the creation of a syntax reference, where each term/phrase is defined in a uniquely named flow. Use of the fully-formatted syntax definitions elsewhere in the document/book would be Text Insets. The re-uses would be hypertext links to the syntax ref, that work properly.
As with all Text Insets, of course, an end-of-paragraph comes in with the text. As I recall, Run-In formatting can be used to deal with that if it's a problem.
