In an effort to troublshoot some issues I'm having I enabled metrics logging in CFADMIN but this is all I'm seeing in the metrics.log file. What gives?
"Information","scheduler-1","11/13/13","15:59:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1737648152 Total memory: 2117206016 Active Sessions: 0"
"Information","scheduler-1","11/13/13","16:00:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1565060456 Total memory: 2117206016 Active Sessions: 0"
"Information","scheduler-3","11/13/13","16:01:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1634382744 Total memory: 2089222144 Active Sessions: 0"
"Information","scheduler-2","11/13/13","16:02:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1532903104 Total memory: 2089222144 Active Sessions: 0"
"Information","scheduler-0","11/13/13","16:03:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1371544704 Total memory: 2089222144 Active Sessions: 0"
"Information","scheduler-2","11/13/13","16:04:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1193930792 Total memory: 2089222144 Active Sessions: 0"
"Information","scheduler-3","11/13/13","16:05:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1749200240 Total memory: 2117664768 Active Sessions: 0"
"Information","scheduler-3","11/13/13","16:06:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1614707664 Total memory: 2117664768 Active Sessions: 0"
"Information","scheduler-2","11/13/13","16:07:54",,"Max threads: null Current thread count: null Current thread busy: null Max processing time: null Request count: null Error count: 21 Bytes received: null Bytes sent: null Free memory: 1485357392 Total memory: 2117664768 Active Sessions: 0"
I found the answer here : ColdFusion 11 Metrics Log NULL values | Chris Tierney
Change the connector port in CFIDE (just below where you check "enable metrics logging" to the one set as the AJP connector port in server.xml - often 8012. You'll have to restart coldfusion.
Lots of ways to double check that, i used
grep -ir 'connector port' /opt/coldfusion10/
You might like to try Java Management Extensions and use JDK tools like Jconsole to measure CF Java and Tomcat metrics.
HTH, Carl.
Thanks, I will look into that. Frankly, this issue seems like just another "bug" in CF10.
anyone found a solution to this problem ?
