Hello.
I have windows vista and adobe framemaker 9 installed with all updates.
My problem is:
when I put a vulgar fraction like two-thirds in round brackets, left bracket is not showing propertly - there are two question marks one over another
right bracket is showing only top part correctly, bottom part is again question mark. (see on the screenshot)
Please help me with this problem.
> I have windows vista ...
I think I found your problem
All seriousness aside, what steps are you using to create the expression?
On both FM9/Win7-64 and FM7.1/Unix, this works.
The results I get appear to be independent of font used, but just in case, what typeface are you using?
hi hi hi vista .... good joke...
... but on win xp and windows 8 it's the same problem.
second thing
you didn;t understand me. I want to write whole fraction in big bracket , not only top and bottom of fraction
If you start with the Delimiter consisting of "(?)",
then select the "?",
then apply Operator "?_over_?_as_one_button",
you get the entire fraction in a single set of parentheses.
of course i should get it but i have something like this
there should be set of parentheses but i see only question marks. if i write normal equations () are ok.
Can anyone put screenshot of inserted fraction in a single set of parentheses?
It can be done in FM9 , FM10 or FM11
I would to know in which version its working correctly.
