I've found a few topics on how to add the standard skin back/next script to a skin, for that I thank everyone. I would like to take it to the next level and make it behave even more like browser buttons meaning when a user has never navigated to a 2nd topic the Back button is unavailable (gray), when they have navigated to multiple topics the button is available (blue). Same for the next button.
Standard script:
For back:
javascript:history.go(-1);
For next:
javascript:history.go(1);
Any ideas?
I believe I saw it somewhere before and now I can't find it.
This requires you to sniff the browser's history. And most browsers see
this as a security threat so they have blocked that. The followig thread
has some suggestions to get this working:
http://stackoverflow.com/questions/3588315/how-to-check-if-the-user-can-go-back-in-browser-history-or-not
Greet,
Willam
This is being used in a CHM that was converted from a Webhelp in RH10 does that make any difference?
Hi there
When you say: This is being used in a CHM that was converted from a Webhelp in RH10, does that mean you are using the feature in RH10 where you are now able to use the CHM as a wrapper in order to present a single .CHM file that presents a skinned WebHelp?
Or are you instead saying that you are now creating CHM output and used to create WebHelp?
Cheers... Rick
Yes, the new feature. I generate the Webhelp then File > Generate > Webhelp to CHM Converter.
I've been doing some research and IE does have security issues with it, I didn't think that would be a problem for the CHM.
You can try, but I don't give you much chance. CHM uses IE under water
and security is possibly even stricter in a CHM than on a regular site.
Greet,
Willam
