Dreamweaver Links
Nov 19, 2013 Nov 19, 2013
About half the time I have to go to the source code to enter a link in Dreamweaver CC.  It will not take them in the options panel.  If I go to source, rool around a bit, then come back to design it will take a lin k properly.  This is a consistent problem'
14.7K
Adobe Employee ,
Moving to Dreamweaver forum.
  • Which ver & build # of DW?
  • Which operating system?
  • Does this problem occur in all pages?  If you create a new, blank HTML page can you insert a link normally?
  • Does this problem occur in all Sites?
  • Do you use any 3rd party Extensions in DW?  Have you tried disabling them?
Nancy O.
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Dreamweaver CC - latest. Win 8.1 - did the same with 8 and 7. All
pages and sites old or new. Do use some extensions but it did the same
before they were installed. Most of the time you enter a link and click
on something else like target or click enter and the link you just
entered goes away. I can go to the source code immediaely after
entering a link in design view and it's not there. I can also go to the
source code and click on anything then return to the design page and
insert a link normally - very strange. This is so annoying I usually
just go to the source code and enter the links there but I shouldn't
have to do that.
Bill
Nov 20, 2013 Nov 20, 2013
@ billkilborn : Just noticed that you need to select / highlight that part of the text which you want to make a link .
  1. Highlight the part of text which ou want to be a link
  2. Go to the Properties Inspector(Window>Properties)
  3. Add the link / target
  4. See them added in Code
Hope this helps
1 - Of course I do that, no other way to do it in design view.
2 - Of course, obvious.
3 - Link can be added but will not stay once you leave the link box.
4 - Does not show in code most of the time once this is done.
Only does this in CC.
Note that I said MOST of the time it does not work the way it should.
If you go to code first then back to design it USUALLY works. This is
very strange.
I've been using Dreamweaver since v2. Been working on websites for
approx. 17 years. Not a novice at this.
Bill
Don't take it personally, there is nothing in your original post that points to your experience level with the program. Part of figuring out problems is verifying the basics, hence the  "is it plugged in" style starting point.
Have you tried clearing the program cache file/config folder yet?
A corrupt program cache can cause all kinds of issues, clearing it will get rid of many of them...
http://forums.adobe.com/thread/494811
No offense taken. I just thought it better to get it out in the open so
others don't waste time with "is it plugged in?"
I did remove the cache file and when Dreamweaver recreated it, it was
the exact same size do don't know yet what will happen. I've got a
bunch of work to do this afternoon and tomorrow, a lot of it in
Dreamweaver, so will let you know. With some of the other problems with
CC I'm tempted to go back to DW CS6 ! !
Bill
Nov 21, 2013 Nov 21, 2013
Followup today:
Had to put in 3 links in a site I do regular maintenance on and the
problem still persists after cleaning the cache as recommended. You can
use the link icon and wizard to add links, add them in code view but
cannot in the options panel of design view. This is not a consistent
problem but happens often. If I come back to design view after working
a bit in code view the options panel method works fine. This is very
strange.
I am finding lots of little nagging problems like this in CC. Another
one I consistently have is I can highlight some text and try to choose a
CSS class in the options panel and it does not work. It will work if I
right click on the highlighted text and choose CSS styles. I can go
back to CS6 and everything works fine. Dreamweaver CC is buggy, buggy,
buggy but other CC products I use are fine. I'm a very regular user of
Photoshop and Illustrator in addition to Dreamweaver.
Bill
I'm definitely not seeing the same behavior in mine (version 13.1 Build 6443) on Windows 7 or Windows 8 (no 8.1 update).
Maybe it was a bad install?
You might try uninstalling, running the cleaner tool and reinstalling/reupdating to see if that takes care of the weirdness.
Cleaner Tool: http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html
Thanks, I may have to do that but no time right now. Things will slow
down a bit after Thanksgiving till mid-January and I'll have some time
to play and experiment then.
Bill
