Locked
How to pass an image from the mobile application to the Adobe Media Server?
Guest
Dec 02, 2013 Dec 02, 2013
The image is taken as photo from the CameraUI in the Client Side(AIR Mobile Application) and saved as a .jpg file in the mobile. I passed the image byte array values from the client to the server. How to convert that byte array to a file in the Adobe Media server?
805
Guest
Dec 03, 2013 Dec 03, 2013
You can use File class to write bytearray to a file. For more details about the same, check the following link:
http://help.adobe.com/en_US/adobemediaserver/ssaslr/WS5b3ccc516d4fbf351e63e3d11a11afc95e-7eacSSASLR....
Guest
private function imageLoading():void
                                        var req:URLRequest = new URLRequest(image file url path);
                                        var urlLoader:URLLoader = new URLLoader(req);
                                        urlLoader.addEventListener(Event.COMPLETE, onURLLoaderComplete);
                                        urlLoader.dataFormat = URLLoaderDataFormat.BINARY;
                                        urlLoader.load(req);
                              private function onURLLoaderComplete(event:Event):void
  imageByteArray = event.target.data;
This imageByteArray is passed to the Server. Server received this bytearray as an Object. How to get the raw  bytearray data from this object in Server side?
Guest
Dec 06, 2013 Dec 06, 2013
You can use NetConnection.call method and pass ByteArray as one of the arguments. For more details about NetConnection.call(), check the link http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/net/NetConnection.html#call...
Also, In the server side you can create a ByteArray object and call ByteArray.writeBytes() method to write the data to server side ByteArray or else you can directly write the ByteArray to a file in binary mode. For more details about ByteArray class see:
http://help.adobe.com/en_US/adobemediaserver/ssaslr/WS37cb61f8f3397d86-59ed32111288f0b936c-8000.2.3....
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/utils/ByteArray.html
Participant ,
This is very similar to the problem here:
http://forums.adobe.com/thread/655314
processByteArray = function(byteArrayAsPlainObject){
     // byteArrayAsPlainObject is an object serialized from a ByteArray but without functions
     // we need to get a ByteArray that we can call functions on
     var usableByteArray = new ByteArray();
     byteArrayAsPlainObject.position = 0; // make sure we start from the beginning
     ByteArray.prototype.readBytes.call(byteArrayAsPlainObject, usableByteArray);
     // now usableByteArray contains what was in the original argument, but we can actually use it on the server side
