So I wanted to try out the new AIR 4.0 implementation of requesting resources in android native extensions using R.* instead of getResourceId. When stepping through the native extension code, anytime the R.* is being used in the native android code it returns an id for the resource, but the resource comes back as null everytime. I assume it is because the resource id is not correct for some reason. I do not know if I am doing something wrong or not. When unpackaging the apk, I could see that the resources are being included correctly in the right folder.
I had to make sure when I exported my jar file from my android project that I did not include the res or gen folders. The gen folder contained the R.java file that is auto-built in the android project, and when packaging the apk would throw an error saying the R.class was already added. So removing the gen folder fixed that.
Here is how I packaged my ANE
extension.xml:
<extension xmlns="http://ns.adobe.com/air/extension/4.0">
<id>com.example.anesample</id>
<versionNumber>1</versionNumber>
<platforms>
<platform name="Android-ARM">
<applicationDeployment>
<nativeLibrary>anesample.jar</nativeLibrary>
<initializer>com.example.aneexample.NativeExtensionSample</initializer>
<finalizer>com.example.aneexample.NativeExtensionSample</finalizer>
</applicationDeployment>
</platform>
</platforms>
</extension>
platform.xml:
<platform xmlns="http://ns.adobe.com/air/extension/4.0">
<packagedResources>
<packagedResource>
<packageName>com.example.anesample</packageName>
<folderName>Android-Resources</folderName>
</packagedResource>
</packagedResources>
</platform>
ane build command:
adt -package -target ane NativeExtensionSample.ane extension.xml -swc NativeExtensionSample.swc -platform Android-ARM -platformoptions platform.xml Android-Resources -C Android .
Folder stucture:
extension.xml
platform.xml
Android
|__anesample.jar
library.swf
Android-Resources
|__values
layout
drawable
etc.
(rest of the resources from the android project res folder)
Note: I do have other ANE's included in the app that are built with older versions of AIR and do not use the new R.* mechanism. I was wondering if that would cause issues or not as well. (I will be doing tests soon that exclude these ane's)
Hi cb_bkelley,
You mention that you had to manually make sure that R.class was not present in your exported jar. It seems you are using a standard Android project to build your jar.
Could you please use an "Android Library project" to build your jar? It would automatically make sure that your jar does not have R.class, apart from other important benefits like generating non-constant resource ids.
I would request you to please create your jar using an "Android Library project" and then share your re
...Copy link to clipboard
Hi cb_bkelley,
I would request you to please create your jar using an "Android Library project" and then share your results. I hope things would work fine then.
Daman
Sorry for the off topic, but could you tell me if the new resource system allows us to override resources packaged inside an ANE with one placed in a res named folder in the main app?
Hi Neverbirth,
The res folder is always qualified by the package name of the project, if the package name of the main app and the ANE is different then there are no chances of the conflicts or overriding.
I hope that helps.
-Nimisha
To make it more clear, I added a picture as a resource for an ANE, that image was a placeholder, and then I tried to override it with a new image from my main app, no matter how I tried, if I had a "res" folder it seemed adt ignored it completely and wasn't packaged in the final APK. Whenever I need to modify that image in a new project I have to open the ANE with WinRAR or similar, and overwrite it from there. Isn't there any other way? Does the new resources system modify this situation?
That did it! Thanks!
