I have generated webhelp using RH10. The webhelp works fine with both Firefox and Chrome but when I display the webhelp from my local machine using IE11 the TOC is missing.
Here is a screenshot.
I also notice that the index is missing as well.
Run in Compatibility mode and add the location as a Trusted Site
RH10 webhelp in IE11 does not work and is a known bug that has been reported to Adobe.
If you run the developer tools in IE11 (F12 key), select the Emulation Tab and change Document Mode from Edge (default) to 10, you will find your webhelp displays correctly.
This is something that MS has introduced in IE11. However, no one has yet suggested a way to make this setting "stick" once the developer tools are closed.
Report this issue as a bug to Adobe - the more users report it, the earlier Adobe may start working on a fix.
There is another work around, forcing IE11 to open the site in an earlier version emulation mode, but apparently this causes problems for users of IE whose version is not the same as the forced mode.
Have a look at earlier posts on this forum about this subject.
RoboHelp 11 fixes this particular issue.
I received an email advising that RH11 fixes the IE11 issues. With great hopes I advised my colleagues, one of whom downloaded the RH11 trial download to install and test their webhelp output.
After converting two of his webhelp projects, unfortunately, RH11 DOES NOT appear to fix the IE11 problems - the table of contents is still missing after importing projects and regenerating webhelp.
C'mon Adobe - a supposed "fix" should work seamlessly first time out of the box.
Could the answer be as in posts 7 and 8 at http://forums.adobe.com/message/6030838?tstart=0#6030838 ?
@Montage9 Did the above fix the problem?
I downloaded the Trial Version of Robohelp 11 and this did seem to fix the issue. Thanks.
