How, I have flash media sever 4.5 and I want to limit only my flash media enconder that can strem to my FMS.
How can I do this?
Thanks.
Also you can do following to restric users as well.
follow section below from link https://www.adobe.com/cfusion/entitlement/index.cfm?e=fmle3 . you have to login with yout credentials and
have to agree with terms and condition.
Adobe Media Server Authentication Add-in (optional)
Using this you will be able to restrict ams access by providing user level access to AMS.
hope this helps you!!
Yeah, even i have same question. please answer if some one knew this.
i try this and it works!!!
You could also use the following tags present in Adaptor.xml at FMS/conf/_defaultRoot_ where you can specify which IP address you want to allow connecting to your FMS and which ones you want to block.
<!-- This tag specifies that clients can only connect to the server from -->
<!-- the specified hosts. This is specified as a comma delimited list of -->
<!-- hostnames or domain names and/or (full or partial) IP addresses. -->
<!-- For example: -->
<!-- "foo.yourcompany.com, macromedia.com, 10.60.1.133, 10.60" -->
<Allow>HERE I PUT MY IPS OF FME</Allow>
<!-- This tag specifies that clients attempting to connect to the server -->
<!-- from the specified hosts will be rejected. This is specified as a -->
<!-- comma delimited list of hostnames or domain names and/or (full or -->
<!-- partial) IP addresses. For example, -->
<Deny></Deny>
<!-- Specifies the order in which to evaluate the <Allow> and <Deny> -->
<!-- tags. This can be "Allow,Deny" or "Deny,Allow". The default is -->
<!-- "Deny,Allow" which means that access is allowed unless specified in -->
<!-- <Deny> and not specified in <Allow>. -->
<Order>Allow,Deny</Order>
Thanks.
Yes!! That works great!
Here are my step so another user can use this:
These are the steps you need to follow :
1. Download the Add-in from here : https://www.adobe.com/cfusion/entitlement/index.cfm?e=fmle3
www.adobe.com/go/learn_fms_authaddin_en.
2. Run the installer on the machine where FMS is installed. For windows run the msi. For linux untar the file and run the installSAA script.
3. The add-in installs the Server Access Adapter (under root_install/modules/access) and the Flash Media Encoder User Management utility (under root_install/conf).
4. Navigate to root_install/conf in the command prompt and run the following to add new user :
users add -u <username> -p <password>
5. Restart FMS.
I think it should be:
./users add -u <username> -p <password>
example:
cd /opt/adobe/fms/conf
./users add -u userme -p 1234567oi
result:
Operation Successful: New user entry added.
Can you tell me how can I put user and password in the rtmp url or something to avoid input user and password everytime I connect?
