Facebook just announced another update to the video tools!
Here is the link for SpeedGrade.
To bad I won't get to use any of it. No renting for me I just wanted to let people know.
http://blogs.adobe.com/movingcolors/2013/12/12/speedgrade-cc-7-2-update/
See what's new in Premiere Pro 7.2 here:
http://blogs.adobe.com/premierepro/
Enjoy!
Peter Garaway
Adobe
Premiere Pro
And here's the list of bugs that were fixed in 7.2:
Import/Export
Import
Export
Playback
Editing
Timeline
Sync by Audio
Merged Clips
Multicam
Nesting
Recording:
Effects and Transitions
Markers
Closed Captions
Metadata: Metadata not editable on network files on windows
Project/Sequence
Project
Relink
Sequence Settings:
Misc.
I don't see mention of fixing the H.264 export that required transcoding by Encore - it is fixed in the AME update. Is it also fixed for exports that are not queued but direct from PR?
See this thread in Encore forum.
Its fixed, just tested it.
Hey all,
I'm trying to figure out if the bug fixes now allow me to have a codec column in the project window. Any one know? Its one of the last things I miss from FCP 7.
That's not an available column.
Would be nice, though, if PP would show you that kind of detail, at the very least in the Properties of a clip.
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Thanks Jim. Every update seems to bring back features I miss so at least theres progress. But in the mean time, do you know of any way to keep track of clip codecs within PP?
You'd have to add that data to the Description or Comment field.
Hi there,
You say the following has been fixed...
Sync by Audio
Having just noticed this post I had to reply just to mention Sync by Audio is not working for me at all, I have this open in another discussion.
I was advised by another member to manually sync!
If this is the only option then I would do this using Elements, I am trailing Pro for this great function.
Still not resolved and I guess I'll be manually syncing in Elements today.
Not great.
Thanks everyone for your support and participation. This thread is primarily a resource to see what was new (features and fixes) for 7.2. If you are having issues with any particular feature (7.2-specfric or otherwise), please feel free to start a new thread (after searching for exisitng ones, of course) so that we can track the various issues in seperate threads.
Hi Mark, although there are a number of fixes related to Markers in Premiere CC, they don't address my problem.
1) When I am editing a multicam sequence with markers, I may shorten the sequence. It has always been annoying that the marker does not have the option to follow the link point when you delete a shot.
2) My biggest problem is that Premiere goes into a Not Responding state when I slide the marker left to its correct position and try to Play. Fortunately, the system actually lets me do a control save at that point. If I then let it crash, by closing the window, I can open up and everything is fine.
3) Another annoyance, is that the markers do not show if I nest sequences, so I have to find the edit points and re-enter them. Is there an option to carry marker over? My work is mostly live concerts, so there are markers at each song start, but I may break the concert up into 'sets'. This reduces some of the delays when working on long sequences, and I find it a better way to work.
Regards
Raymond
I just want to confirm that the crash when using a border for wipe transitions is still there. You can add the border, you can play through the transition, but once you park the CTI at the edit point with such a transition - crash city baby!
