My scenario:
Windows 7 x64
Flash Player 11.7
mms.cfg located in C:\Windows\Syswow64\Macromed\Flash
mms.cfg settings:
AutoUpdateDisable=1
SilentAutoUpdateEnable=0
I opened the Flash Player Settings Manager and under Advanced tab, verified "Never check for updates" is enabled.
I have both Standard and Administrative users receiving the following warning to update Flash player. Again, I have verified the settings are correct and auto update is showing as disabled.
There have been many reports of fake update pop-ups, but the screenshot you posted looks genuine.
When you get that pop-up again, could you check the Task Manager's Processes tab, and see if you can identify which process is issuing it?
P.S. hopefully someone from the Flash Player team will also have a look at your post.
The message popped up again today. The process was FlashUtil32_11_7_700_202_ActiveX in C:\Windows\SysWOW64\Macromed\Flash
I again verified in the Flash Player Settings Manager that 'Never check for updates (not recommended)' is selected.
I don't know if the processes the first time was ActiveX or Plug-in.
I also want to point out that not everyone is receiving this message, only some are.
We are seeing the same thing. I was going to post about it but it suggested I read this post. Which has not been answered. I am following all of the documenation for disabling flash updates and the control panel icon is showing that checks are disabled. I even went as far as disbaling the Flash Updater Service and removing the scheduled task Flash creates for whatever reason. As far as I can tell i have disabled this updater in 4 different places and some users are still getting prompted. Is this a bug? It used to work up until the last few months. Thanks.
We are getting this issue as well for our users.
Currently running 11.9.900.117 on Win7 64bit Pro. Update to 11.9.900.152 is available and is NOT silently installing despite fact that mms.cfg is in users c:\windows\SysWow64\Macromed\Flash\ folder and set to
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
Users are standard users not in admin group for their computers. We are getting many calls to help desk about this. The updates are supposed to be silent, aka no notification or interaction presented to users. Searching the forum & bugs this goes back to April of this year.
When is Adobe going to fix this?? We are tired of getting calls regarding this.
We've experienced this issue for quite some time now. We have AutoUpdateDisable=1 in mms.cfg, stored in %windir%\syswow64\Macromed\Flash\. If I look in the Flash Player settings, I see that automatic updates have been disabled. Yet several of our users get the update dialog.
It's amazing to me how Adobe is not taking it seriously. I have posted a bug report in the bugbase, and from searching this forum it's pretty clear that the problem is common.
I have posted my issue into bugbase as well.
I'm guessing Adobe is too busy doing damage control as a result of their latest "we lost all your passwords" hacking to fix something like this.
Not prompting the users for updates (and either silently updating or never updating) is an essential feature for business/enterprise deployments.
When the users get prompted they get confused and calls come in to the IT Helpdesk. Both groups are then not happy.
I can't understand how Adobe cannot be on fixing this immediately.
Dear ituser22,
Player 11.9.900.152 is our LOUD release, which means SilentAutoUpdate service is not enabled in the following 30 days even if you set "SilentAutoUpdateEnable=1" in mms.cfg. So, if you have player 11.9.900.117 installed on your computer with AutoUpdate service enabled (set "AutoUpdateDisable=0"), you will see the update panel popping out and leading you to our PDC center to download the latest flash player.
We are sorry that our upgrading process confused you so much. Hope this note is useful for you. Thanks so much!
This doesn't answer the original question which is, why are we seeing prompts for updates even though we disabled automatic updates. Thanks.
Thanks for the reply!
We are looking into issue now, but unfortunately we couldn't reproduce this issue. We may need your help. If the issue still exists with your computer, would you please do us the favour to provide more details?
1. Your OS type, your browser type, and the player version you are using.
2. The installation logs.
For windows 7 64bit, the log is under C:\Windows\SysWOW64\Macromed\Flash
For windows 7 32bit, the log is under C:\Windows\System32\Macromed\Flash
For Mac OS, the log is under: /Users/User_ID/Library/Logs/FlashPlayerInstallManager.log
We may find some clue through the installation logs so that we could fix this issue as soon as possible. Thanks again!
I have uploaded the flashinstall.txt file to bug#3673004
Anping wrote:
Dear ituser22,
We're also seeing the same issue and have a similar environment to the original poster and ituser22 (Windows 7 Enterprise x64 running 11.9.900.117 with AutoUpdateDisable=0 and SilentAutoUpdateEnable=1).
On an equally important note, how can administrators tell which updates are "LOUD" releases and will need to pushed out via Group Policy (or equivalent) even if silent auto-updates are enabled? I kept expecting our machines to update automatically as they had previously done and then finally created a manual update after reading your post. It would be very helpful if Adobe LOUDLY made it clear in the security bulletin for a release that it would not update automatically. I couldn't find any mention of it in the bulletin for 11.9.900.152. Thanks.
The original poster did not have the same settings. He was disabling autoupdates altogether. As am I. And we are both still getting prompted for updates. Do silent updates even work? I assumed it would prompt for admin rights, which our users do not have. The idea of supressing updates is so that IT can manage the deployment using tools that dont need local admin rights (SCCM). Our users are used to us handling updates for them. When they get a prompt about flash updates we look bad and Adobe looks worse (they already look bad daily). I'm surprised you can't recreate it. Maybe this bug was finally fixed in 11.9.900.152?
I should have clarified that our environment is a mixture of the original poster's and ituser22's. More importantly, I should have proofread my post more carefully since we actually have AutoUpdateDisable=1 rather than what I originally posted (and can no longer edit). I apologize for the confusion.
Silent auto-updates do indeed work (at least they did until the 11.9.900.152 release). They use the background updater service that runs as the SYSTEM user so it updates even though all my users don't have admin rights. The service was already installed with Flash (introduced in 11.2, I believe) so all I had to do was push out the mms.cfg file. When combined with AutoUpdateDisable=1, it should also remove any prompts to the user about updating, although clearly that part is not happening.
Oh cool. To me it seems like AutoUpdateDisable=1 and SilentAutoUpdateEnable=1 are conflicting settings. In one setting you are say disable autoupdate and in the other you saying to enable it, but do it silently. Maybe that's why it works. They are treated as wholly separate settings.
It would be nice to use the SilentAutoUpdate and get out of the business of deploying plugins but we like to test the plugin first before giving it to our users. Good to know that service works. I actually went as far as disabling that service with GPO and it was STILL prompting for updates somehow.
Agreed. In fact, when I originally created the mms.cfg, I had AutoUpdateDisable=0 because it wasn't initially clear to me that setting controlled only the automatic update prompts (the "regular" automatic update) rather than the silent updates. I can see the potential value in having a separate setting for each option but the naming convention could be clarified, especially when one says Disable and the other says Enable.
If you are referring to disabling the background updater service, it's possible that service only works in conjunction with the silent updates and would therefore not affect the update prompts (although I certainly can't state that definitively).
Hello,
Unfortunately, it's difficult to troubleshoot this issue after the fact due to how the auto-update notification is triggered. If auto-updates are disabled in the mms.cfg file the update notification should not display, however, there is an edge case scenario that could result in the update notification displaying.
First, to clarify some comments regarding the update settings in the mms.cfg file:
The default update settings are:
Silent auto-update is an opt-in option, it is not the default setting. When installing using the EXE installer if the system is not already opted into silent auto-update the user will be prompted to select an update option and the mms.cfg file will be updated with this selection. The MSI installer does not write to the mms.cfg file, therefore, it does not prompt the user to select an update option. When Flash Player is installed using the MSI installer Flash Player simply honors whatever settings are already present in the mms.cfg file.
SilentAutoUpdateEnable=1 enables silent auto-update ONLY if AutoUpdateDisable=0 is set.
AutoUpdateDisable=1 disables notification AND silent auto-updates
As of Flash Player 11.5, uninstalling Flash Player using the standalone uninstaller will reset the update options to the default setting (documented on page 8 of the Flash Player Administrator's Guide):
If your Flash Player deployment process is to first uninstall the Flash Player using the standalone uninstaller and then install Flash Player using the MSI installer the system will be configured for notification updates since this is the default setting. In this case you must re-deploy the custom mms.cfg file to disable updates at the same time Flash Player is installed using the MSI installer (e.g. uninstall, install using MSI, deploy custom mms.cfg file disabling updates). If the custom mms.cfg file disabling updates is not re-deployed at installation time it is possible for Flash Player to detect an update is available resulting in the upate notification displaying.
Regarding 'loud' releases, if you rely on silent auto-updates to update Flash Player within your organization, and want to avoid the update notification associated with a 'loud' release, you can host the updates on an internal server. Details on how to do this are on page 19 of the Flash Player Administrator's Guide.
This functionality is tested extensively and we have not been able to reproduce the update notification displaying when updates are disabled. Nonetheless, I will try using the various Flash Player versions mentioned in this thread.
Maria
Maria, thanks for the information.
Is it possible that by having SilentAutoUpdateEnable=0 in my mms.cfg causes the occasional popup to update by somehow interfereing with the AutoUpdateDisable=1?
Thanks for the detailed response Maria. I can say I currently only use AutoUpdateDisable=1 in my mms file and was seeing the prompts. We use only the MSI version from the enterprise deployment website and let it do it's thing with regard to removing the previous versions. We recently deployed the latest version and I'm hoping we won't see prompts when the next version releases.
Also with regard to how we are deploying the mms file. We use group policy preferences. That way even if the user or the installer delete or change the mms file, group policy comes back down and sets it back the way we want. To disable auto updates. The weirdest part is that the control panel applet shows disabled yet some users report they are getting prompts.
@bigdogchris,
AutoUpdateDisable=1 is the overriding setting, which disables everything. How are you deploying Flash Player in your organization?
@axeshredder1,
How often does the Group Policy task run? If there's a lag between the time the user modified/deleted the mms.cfg file and Group Policy resetting/recreating the custom mms.cfg file it's possible that Flash could have detected an update is available and configured the system for the notification update.
Maria
Hi Maria,
Thanks for clarifying the settings. Is there any way to tell which flash releases are "loud?" Thanks.
We also use Group Policy Preferences for deploying the mms.cfg file. Great tool.
Maria, Group Policy refreshes by default every 90 minutes on windows clients. However, most of our users are not running as admins nor would they ever mess with that file. So to my knowledge that file always stays the way we set it (especially since we use the MSI to deploy Flash). Thanks.
