Is it me or is it no longer possible to return to an iOS app in AIR 4.0 beta? An app I just compiled restarts every time you launch it. No such problem in AIR 3.9.
Just yesterday I saw a problem where going to the home screen and back would either crash the app or would leave it in a frozen state. It only happened if by that time I had been via a part of the app that played an animation that used stream audio.
Might you be seeing the same kind of thing, where you can go in and out of your first screen, but get crashes or hangs when going from another screen?
I didn’t log a bug yet because it’s a hard problem to narrow down, because the crashing happens when you return to the app, and so doing a debug session won’t help, the session closes when you go to the home screen.
Hi Colin,
Are you using latest beta build which was released on 10 December? If yes then can you please share the your app with me @nimisha1@adobe.com so that I can repro the issue at my end as well?
Nimisha
Hi Colin,
This issue is fixed in latest beta build 1390, please try and share your feedback with us.
Nimisha
Yes, I did a build again with the earlier version, to confirm that it was still broken. Then I tried yesterday’s build, and it does fix the issue.
