I have Windows 7, and am trying to update a FM 11 book. When I click the update book icon, the software starts updating but then hangs indefinitely. I have to go to task manager and end the FM task. I have the latest update, 11.0.2. I cannot add an index because that requires the book to be updated. Prior to updating I have verified there are no unresolved cross-references. I am using structured Frame. Any suggestions?
Thank you,
Tani
Edited to add, I don't believe it matters whether I am using structured or unstructured, does it?
Try opening all of the component parts of the book first & then update - you may get a message about one of them that's being suppressed in the "silent-open" that FM does when it tries to update a book.
All book files are open, but book still won't update.
getting any warnings?
Open all the files in the book and then try the update.
Most likely problem is that you're getting unavailable fonts or broken
cross-ref messages for one or more component files as they're being opened.
Because you're running a background process, there isn't a way to
acknowledge the error message, so the file never opens, so your update
doesn't complete.
Opening all the files first, before the update, allows you to ack any
error/problem messages. If you are receiving some, pay attention to them
because you should resolve them at some point.
Art Campbell
art.campbell@gmail.com
"... In my opinion, there's nothing in this world beats a '52 Vincent and
a redheaded girl." -- Richard Thompson
No disclaimers apply.
DoD 358
I support www.TheGrotonLine.com, hyperlocal news for Groton MA.
No unavailable font messages and I verified no unresolved cross-refs.
Well, then, time to either toss out each file one by one until it updates OR create a new book and add files one by one, updating as you go, until it crashes.
Jeff, I found the corrupt chapter and re-built the book using a new (had to re-write) chapter. Was able to update the book afterwards. Thanks to you and Art for your help.
Tani
OK, if you have all the files open, didn't get any error messages and still
can't update....
I suspect that at least one of the files is corrupted somehow. First, make
a backup copy of the book.
Then, try saving the .FM file out as .MIF, opening the .MIF and saving it
over the source .FM file. (If you download a trial of MIF2Go from mif2go.com,
they install a utility program that "MIF-washes" all the files in the book
at once -- it's a useful tool.) Saving as MIF should parse the file and
remove any corrupted characters or embedded trash (such as you might have
by pasting in Word content, for example).
After you've processed all the files, try the update yet again.
If that doesn't work, I'd opt for Jeff's suggestion of eliminating
problematic files, one by one until you locate the problem.
Cheers,
Art
Art Campbell
DoD 358
