I'm trying connect to database using flash builder.
I'm click Connect to Data / Service... under Data Services.
selecting PHP and insert a db user, hostname, dbname etc.
but when I trying to connect database, i seeing an java.io.EOFException error.
I trying to using 3306 , 80 or blank database port but seeing a same error.
how can i fix this error and connecting a database.
you can see a screenshots.
nobody knows it ?
i try everything because still experiencing a same problem.
I'm connect to database and select database and table. but when I finishing a connecting process, I'm seeing a this error message.??
What should I do?
Server error
Directory argument must be a string or an array
#0 C:\xampp\htdocs\mobile\ZendFramework\library\Zend\Amf\Adobe\Introspector.php(96): Zend_Loader::loadClass('UyeService', false)
#1 [internal function]: Zend_Amf_Adobe_Introspector->introspect('UyeService', Array)
#2 [internal function]: ReflectionMethod->invokeArgs(Object(Zend_Amf_Adobe_Introspector), Array)
#3 C:\xampp\htdocs\mobile\ZendFramework\library\Zend\Server\Reflection\Function\Abstract.php(380): call_user_func_array(Array, Array)
#4 C:\xampp\htdocs\mobile\ZendFramework\library\Zend\Amf\Server.php(359): Zend_Server_Reflection_Function_Abstract->__call('invokeArgs', Array)
#5 C:\xampp\htdocs\mobile\ZendFramework\library\Zend\Amf\Server.php(359): Zend_Server_Reflection_Method->invokeArgs(Object(Zend_Amf_Adobe_Introspector), Array)
#6 C:\xampp\htdocs\mobile\ZendFramework\library\Zend\Amf\Server.php(553): Zend_Amf_Server->_dispatch('introspect', Array, 'Zend_Amf_Adobe_...')
#7 C:\xampp\htdocs\mobile\ZendFramework\library\Zend\Amf\Server.php(629): Zend_Amf_Server->_handle(Object(Zend_Amf_Request_Http))
#8 C:\xampp\htdocs\mobile\mobile\gateway.php(69): Zend_Amf_Server->handle()
#9 {main}
