I have a LEGAL version of CS6 Design & Web primium. I have installed it about a year ago and registered bij Adobe. If I look on the site, my CS6 and licensenumber is available. Still it does not work. Eveytime it says my trail version comes to an end and I have to buy it. But I already bought it.
I tried to reinstall, but that does not work either. How can I get it to work again???
Thank you for your help.
I bought this software with a teacherslicense. It was told that is was
unlimmited. But it isn't. Mistake from the supplier who has given me a
solution. Problem is solved.
2014/1/1 Jeff A Wright <forums_noreply@adobe.com>
Re: License CS6 Design & Web Premium does not work anymore created
by Jeff A Wright <http://forums.adobe.com/people/JeffAWright> in *Downloading,
Installing, Setting Up* - View the full discussion<http://forums.adobe.com/message/5971614#5971614
uninstall
run the cleaner, http://www.adobe.com/support/contact/cscleanertool.html
restart your computer
reinstall cs6
if there's a problem reinstalling, attach a screenshot of the error message or the dialog that appears after entering your serial number.
Hello, Thanks for your reply. I tried the above mentioned methode, without succes. <Image removed due to containing serial number>
MSnhl do you receive a specific error message when you enter your serial number?
Hello, thanks for your reply. See my answer to kglad. I removed the programm, run the cleaner, restarted en reinstalled. But unfortunately without succes.
MSnhl I have removed your posted image as it contained your serial number. Please be aware this is a public forum.
I would recommend you contact our support team so we can verify the validity of your serial number. You can contact our support team at http://adobe.ly/yxj0t6.
Thank you.
I live in the Netherlands. I wanted to make a call back request, but that
is not possible. I also can not start a chat session.
I checked the serial number with the number at my Adobe account and it is
correct. How can I get in contact??
MSnhl if you are unable to start a chat session please try a different web browser. You can also find our contact information at http://helpx.adobe.com/nl/contact.html.
I checked the serial number with the number at my Adobe account and it is correct. How can I get in contact??
Thanks for the update MSnhl yes this seems to be a common cause around this time of year. I am happy your supplier was able to get it sorted out.
