hi
I am doing the flex in a week course. Pain in the butt to see the design view is gone but hey no worries.
Anyway, I run the mxml and nothing shows up. I also ran the swf that was produced and yes - empty. However the code seems to be fine so I am confused.
</s:Application>
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx"
minWidth="955" minHeight="850">
<!-- Exercise 1.01: Setting up your project files -->
<!-- Styles ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
<fx:Style source="Styles.css"/>
<!-- Script ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
<!-- Declarations ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<!-- UI components ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -->
<s:Label x="10" y="34"
width="690" height="40"
text="Employee Portal: Vehicle Request Form"
styleName="titleHeader"/>
<s:Form x="10" y="70">
<s:FormItem label="Employee:">
<s:DropDownList/>
</s:FormItem>
<s:FormItem label="Office Phone:">
<s:TextInput/>
</s:FormItem>
<s:FormItem label="Mobile Phone:">
<s:TextInput/>
</s:FormItem>
<s:FormHeading label="Dates Requested"/>
<s:FormItem label="Pickup Date:">
<mx:DateChooser/>
</s:FormItem>
<s:FormItem label="Return Date:">
<mx:DateChooser/>
</s:FormItem>
<s:FormItem>
<s:Button label="Submit Request"/>
</s:FormItem>
</s:Form>
Are you sure you are running the right mxml? Some times doing a clean build also helps. Sometimes the html template files (js files) are missing that cause a javascript error and nothing to load. Usually, project clean build does it. If you right click on the generated swf what does it say?
Hi, thanks for asnwering.
I just started a new project from scratch and all is fine. HOWEVER, I had been reading extensively about creating dashboards and was advised to use a responsive design in html5 + css etc... but still use php and mysql. ie: Someboady advised me to stop using flex as that would not be a viable solution for tablets and mobiles and the flash player is not supported. I know we have the AIR run time but this is supoposed to be a dashboard running in the browser so teachers can log in and check out kids results. I don't know if you have any opinion about this.
Cheers
