I have coldfusion enterprise installed with version 9,0,0,251028.
May I know how to update to the latest version incorporating all the security fixes, and the latest version number to which it will be upgraded to?
arun
Hi arun,
You could update to CF 9.0.1 + CHF4 + security patch.
9.0.1 update EXE from here:
http://www.adobe.com/support/coldfusion/downloads_updates.html#cf9
Cumulative Hotfix 4 from here:
http://helpx.adobe.com/coldfusion/kb/hot-fixes-coldfusion-9.html#ColdFusion 9.0.1 hot fixes
Security patch APSB13-13 and 27 from here:
http://helpx.adobe.com/coldfusion/kb/coldfusion-security-hotfix-apsb13-13.html
and
http://helpx.adobe.com/coldfusion/kb/coldfusion-security-hotfix-apsb13-27.html (note use 9.0.1 section 2)
Once CHF4 is applied Java 7 is supported so you might like to use that rather than EOL Java 6 as likely is current.
http://www.oracle.com/technetwork/java/javase/downloads/jdk7-downloads-1880260.html
A CF 9.0.1 system information says:
Version 9,0,1,274733
Update Level /E:/ColdFusion9/lib/updates/hf901-00011.jar
CF 9.0.2 (latest build CF9) would be an uninstall and re-install using 9.0.2 installer.
HTH, Carl.
Thanks, Carl. I will try the steps and let you know.
Hi, Following the instructions above, in this link -
http://helpx.adobe.com/coldfusion/kb/hot-fixes-coldfusion-9.html#ColdF usion 9.0.1 hot fixes
It says:
7. Go to {CFIDE-HOME} and take a backup of CFIDE folder.
8. Extract all the files in CFIDE-901.zip to merge in the web root directory that has {CFIDE-HOME} folder.
Question is, where do I find the {CFIDE-HOME} folder? It is not present in my installation of CF9.0.0; I checked under -
{coldfusion-home} and {coldfusion-home}\wwwroot\
It does not seem to be present.
In CFADMIN (http://domain/cfide/administrator) > Server Settings > Mappings
What value do you have for "Logical Path /CFIDE" Directory Path? EG C:\inetpub\wwwroot\CFIDE
HTH again, Carl.
Thanks again, Carl. Found the folder.
