Hi All,
I installed apache as:
And CF10 as:
http://iknowkungfoo.com/blog/index.cfm/2013/2/27/Installing-ColdFusion-10-on-OSX-108-Mountain-Lion
In my other MAC I was able to fix my issues with my installation as:
http://forums.adobe.com/message/5671892#5671892#5671892
The Apache is running, aparently CF is running also:
$ /Applications/ColdFusion10/cfusion/bin/coldfusion restart
Restarting ColdFusion 10 server instance named cfusion ...
Stopping ColdFusion 10 server instance named cfusion, please wait
ColdFusion 10 server instance named cfusion has been stopped
Starting ColdFusion 10 server instance named cfusion ...
The ColdFusion 10 server instance named cfusion is starting up and will be available shortly.
ColdFusion 10 server instance named cfusion has been started.
ColdFusion 10 will write logs to /Applications/ColdFusion10/cfusion/logs/coldfusion-out.log
But I cannot see the admin page of CF.
https://localhost/~myUserName/CFIDE/Administrator/index.cfm
ERROR:
Unable to connect
Firefox can't establish a connection to the server at localhost.
I cannot open any cfm page content on my Site Folder.
What is missing? Why I cannot opent the CF admin page?
Please help.
As you have applied the update 13 then you need to reconfigure the connector. So remove it and configure it once again. Check this : http://blogs.coldfusion.com/post.cfm/video-configuring-coldfusion-10-connector-with-apache-virtual-hosts
Test the update 13 : http://helpx.adobe.com/coldfusion/kb/coldfusion-10-update-13.html
Thanks for you reply and help!
I did the update. The apache is configure the same. Reboot the laptop.
CF is running, I checked using terminar services.
But I cannot login into the CF admin page.
My test file shows the text <cfoutput>#now()#</cfoutput> instead of the time.
Any ideas how to degug this?
Best,
Enable the buit in port 8500 in the server.xml as mentioned below and then login to CF. See if that works or not?
<!-- internal webserver start -->
<Connector executor="tomcatThreadPool" maxThreads="50"
port="8500" protocol="org.apache.coyote.http11.Http11Protocol"
connectionTimeout="20000"
redirectPort="8445" />
<!-- internal webserver end -->
Once the internal port is enabled, restart CF 10 service, place the test.cfm which contains <cfoutput>#now()#</cfoutput> in wwwroot folder. Access this test.cfm like http://127.0.0.1:8500/test.cfm
VJ
You rock!
Now i am able to get into the CF admin page.
I know that MAC have two webserver folders. I am using the /Users/username/Sites/
When I do: http://127.0.0.1/~johnnyballadares/index.htm, it works fine
When I do: http://127.0.0.1:8500/~johnnyballadares/index.htm, I got error 404.
When I do: http://127.0.0.1:8500/~johnnyballadares/index.cfm, I got File not found.
When I do: http://127.0.0.1:8500/index.cfm, I got File not found.
So coldfusion is up but the cfm pages are not working???
I appreciate your help.
Best,
inside CF10 wwwroot folder place a test.cfm (<cfoutput> Hello CF 10 on Mac </cfoutput>) and then browse it as http://127.0.0.1:8500/test.cfm
That works, but how can I use cfm files in my /Users/username/Sites/ webroot folder?
What is working now is the CF 10 webroot. Now you need to configure CF 10 with any webserver (I beleive it is Apache). Launch the wsconfig.exe and see that is there any connector or not.
VJ
Yes the conector is there: [localhost:cfusion] Apache : /private/etc/apache2
As you have applied the update 13 then you need to reconfigure the connector. So remove it and configure it once again. Check this : http://blogs.coldfusion.com/post.cfm/video-configuring-coldfusion-10-connector-with-apache-virtual-h...
I got permission denied. I stop CF and apache server but still the same issue.
Is this my solution?
I cannot drop and create a new one?
I was able to delete the connection using terminal with admin rights.
Now it is asking for
AppServer Host = localhost
AppServer Cluster = ^
Web Server = Apache
Configuration Directory = /private/etc/apache2
Do I need to setup anything else?
It works... thanks again!
Best,
