can anyone help create variable for page number RunningH/F for every other page blank? I have created one but need a variable for the BLANK page number to be added automatically (like the current page number)! I do not want to build a page number manually for each page simply because I can not get the blank page number to automatically be added incrementally. They need to look like.......FO-1/(FO-2 blank), FO-3/(FO-4 blank), FO-5/(FO-6 blank), etc.
So you want odd-numbered pages (with content) to show a page number of:
"FO-"<$curpagenum>
and even numbered (blank) pages to to show a page number of:
"(FO-"<$curpagenum>" blank)"
if so, just format the Left and Right master page headers or footers as:
FO-#
and
(FO-# blank)
where "#" is the variable <$curpagenum>
How are you creating the blank pages?
A paragraph format named "Blank",
font color: invisible named color (controlled by Color Views)
pagination: top of left page
usually does the trick.
NOT EXACTLY, and herein lies the problem………..
The page number will always be visible on the right hand page, thus showing FO-1/(FO-2 blank). The next page (being left hand page) BLANK and will not have ANYTHING on it.
The next right hand page will have visible FO-3/(FO-4 blank)!
I cannot figure out how to automatically get the 2, 4, 6, etc. blank number to come in!!
Might the “marker” idea work? I don’t understand how to set it up or if I understand completely; hence, me being in a pickle and need help.
Thanks so very much for your response and help.
Ah. The challenge there is getting page P to to pick up the page number from page P+1. Frame doesn't make that easy to do, as
variable <$curpagenum> is only available for Master Pages, and not Body Pages, and
you can't Cross-Ref to an MP and get the correct pagenum, and
Running H/Fs only read from the current page, and not the next.
FM also doesn't support any math ops on entity numbers, alas, other than simple paranum expressions.
I'm not sure what Marker trick you had in mind, but it wouldn't be Frame if there were one way to solve a problem.
Offhand, I can mostly visualize a complex Cross-Ref / Running_H/F hack for this, but won't post it until we first see if some other contributors have more elegant solutions.
Assumption:
Each content page has something unique, that uses that same paragraph tag on each content page (my example assumes a Heading2).
You can run this test on a new, empty duplex document.
In your actual document, make your body text frames, at least for Right pages, one text line taller than they need to be. This holds an extra invisible bottom line on the content pages, used for Running H/F pickup.
1. Format Setups
View > Color > Definitions
Process
RGB 75 50 75 (or whatever you like)
Overprint
[Add]
View > Color > Views
Move "Invisible Content" to to "Normal:" for whatever View# you use for authoring (we use#6). Move it to "Invisible:" for all other view numbers.
[Set]
Click in a normal Body para somewhere
Format > Paragraph > Designer
Tag: ForceBlank
Commands: New Format
Basic:
[Heading2]
Default Font:
Color: Invisible Content
Pagination: Top of Left Page
Numbering:
[FB after page: ]
[Update All]
Note: The autonum is not required, but if your ForceBlank paras don't have some unique content, they will be impossible to distinguish in the Xrefs dialog from NextPage paras.
Tag: NextPage
Basic:
[ForceBlank]
Default Font:
Pagination: Anywhere
Special > Cross Reference > Edit Format
Name: [<$pagenum> (only) ]
Def: [<$pagenum> ]
[Add]
View > Master Pages
Click in the header.
Special > Variable:
Running H/F 12
[Edit Definition]
change
paratag
to
NextPage
[Edit] [Done]
Display Master Page Right.
Click in header.
Type in:
This is page A. The next page is B.
Set A to variable <$curpagenum>
Set B to variable Running H/F 12
View > Body Pages
2. Create initial Body content instance
Create a Heading2 with some xyzzy content.
Start a new line.
Apply tag NextPage
Hit return, which will create a new page and an empty para of tag ForceBlank. This example assumes that NextPage will be the last para on every content page.
With cursor in para ForceBlank,
Special > Cross-Reference
Source Type: Paragraphs
[Heading2]
Paragraphs:
[ pick the xyzzy content ]
Reference:
[<$pagenum> (only)]
[Insert]
This makes this para unique in the Xref dialog's list, see we can Xref it by page#.
Go back to the previous page.
Click in the NextPage para.
[ForceBlank]
Paragraphs: look for
[FB after page: 1]
Reference:
[<$pagenum> (only)]
[Insert]
This puts page number P+1 on page P, in the Flow_A text.
Edit > Update References
The header should now say:
This page is 1. The next page is 2.
QED
If your content page don't have unique para formats that always appear, like the HEading2 in this example, the ForceBlank para could just Xref to the preceding NextPage para, idoes exist on each preceding content page.
3. Create more instances.
You can now copy that NextPage/ForceBlank para pair to every body page, and update the Xrefs to each other. They won't need edits after that, even when pagination changes, and you'll never need to type in actual page numbers.
4. Rendering
For a book, in the book menu, select all component files.
Select the view number you use for various editions which do not display color "Invisible Content".
[Set]
Render. (Save-as..., Print, etc.)
OK, first step accomplished.
For the next step below……..I want to be sure I understood correctly……..
I performed this step accordingly:
1. In the “Define Color Views” I moved “Invisible Content” from the “Normal:” block to the “Invisible:” block after selecting “View 1” and each view through “View 5”
2. For “View 6” “Invisible Content” remains in “Normal:” block
Is this correct? How do I know which “View” is used for authoring here? I have NEVER toyed with this, I guess I’m somewhat of a beginner when it comes to all that Framemaker is capable of doing.
Thanks much,
Adobe doesn't provide much help on what you would use Color Views (CV) for, much less what each view number might mean. And no, you can't name them in the app (at least in the FM7.1 we use).
CV is great for content that needs to (or at least can be) turned on and off without causing a reflow, such as the Invisible Content paras above. This is different than Condition Codes (CC), where reflow happens whether you want it or not, and Xrefs can easily get broken. We use CC where we want reflow when the content is switched on/off.
We use CV for rendering editions. Our current convention (and it's just a convention) is:
So you'd author in, say, CV#6, so you can see all the meta-text, then switch to one or another CV# for rendering with the meta turned off.
SO, did I do this part correctly?
FWIW, treat FM's Color Views as you would a layer in other applications (like Illustrator, Photoshop). The visibility of the objects is tied in to the color attribute applied to the object. The Color Views let you set up to six different ones where each color can be independently set to show (Normal), clip out underlying colored objects (Cutout) or Invisible (i.e. it can not be seen nor will it print, but FM knows that the content is still there and can reference or link to it).
By default, most FM documents are set to be in Color View 1 and the View is a document level property (i.e. a template may set this to another View number).
You can easily toggle between views using the shortcut <esc> v #, where #=1 to 6. [bonus: <esc> v v toggles all graphics on/off] The keyboard shortcut also works at the book level to change the View in all files of the book in one quick keyboard shortcut.
Good Morning,
New Issue……when I “Update Book” the error log is the same ALL THE TIME! As I mentioned before I know nothing about the color stuff but, I am using simple Arial and Times New Roman for EVERYTHING and have checked these files that say my font is unavailable but, find nothing inconsistent with all other files nor do I find anything other than the arial and TNR!! What the heck is going on???
REALLY need to get this stuff ironed out before WEDNESDAY!!!!!
Thanks so much,
CherylAnn
Search the forum for “unavailable fonts” – there’s a number of posts that have troubleshooting guidelines for eliminating where these pesky fonts can hide.
Thanks so much!
You need to use the Camera icon in the Web interface if you want to show us screenshots or error logs – no attachments are permitted in the forum.
Want to post pictures? Use the Camera icon in the Web interface version of the forum..
> I performed the “Pagination: Top of Left Page” step and then the following was generated…
Link is circular.
I didn't include all the [Apply] dialogs that pop up, and some ops probably do require that you be specifically in Body or Master Page mode.
OH………am I working in the “Master Pages” or the “Body Pages” platform?
OK………I am ALMOST there! Starting from scratch, I got down to “Display Mater Page Right. Click in header. Type in:……”(see below in original message red text)!!!
This is where I am not clear at all………..do I type all that in one line exactly as you have it? Do I add returns? I the header you mentioned really supposed to be the footer where I want my page number to appear on the body page???
So sorry….consider me your challenge for the day! ;0)
> ... see below in original message red text)!!!
??? I see no red text anywhere.
> ... do I type all that in one line exactly as you have it?
I did, into the default Header para type. it's just a demo, to show that the MP header can be made to show both the current page number, and any other arbitrary page number (in this case, the next page), by using a user-defined Running H/F variable to grab local page content that is actually an Xref to the away page ... with some tweaks to aid stewardship and presentation.
> ... header you mentioned really supposed to be the footer where I want my page number to appear on the body page???
Can be header or footer as long as it's a Background text frame on the Master Page: Right.
> ... consider me your challenge for the day! ;0)
Well, mine is winding down, so some of this may be left as homework for the student. It sounds like you have a bit to learn about paragraph formats, cross-references, cross-reference formats and variables.
OK, I’m with you! I have much to learn and I will fight with this more tomorrow! Will try not to bother you too much but, I would REALLY like to get this little task accomplished! After this is done, the rest of the job is ho-hum!
Thanks so much and have a great evening!
