I'm trying to compile my mobile app with the new -useLegacyAOT no flag.
Compilation goes well and when installing and launching the app (release build) on iPhone 5 with iOS 7 I get the following messages on Scout:
Adobe iOS
External interface not available
0 - Init
Error: ga.js not found, be sure to check if
<script src="http://www.google-analytics.com/ga.js"></script>
is included in the HTML.
And then an error is thrown and obviously the app crashes.
When I compile without the new flag I get the following expected output and the app starts flawlesly:
Adobe iOS
0 - Init
Init Database
(And the rest of the trace statements from the init)
So the ga class fails only when I use -useLegacyAOT no.
I use "AS3" mode to initialize the tracker so I wonder why it's trying to find the ga.js file when the new compiler is used...
Someone can share some light about this issue?
Could you please provide us the sample application, this would help us in reproducing the issue quickly at our end.
Thanks for reporting,
Ankit
I'm getting this same issue.
Error: Error: ga.js not found, be sure to check if is included in the HTML.
I'm getting the same error since moving to AIR 15:
"ga.js not found, be sure to check if
<script src=\"http://www.google-analytics.com/ga.js\"></script>
is included in the HTML."
This is an URGENT issue in AIR 15.0. Right now GA does not work in this framework.
Thanks for reporting the problem, but we haven't encountered any such issue. Iit will be great if you could provide us sample app or code so that we can reproduce the problem at our end.
Jitender
It's common knowledge that some ANEs (or SWCs perhaps) are not compatible with the new compiler. I'm pretty sure that some of your colleagues, or your bug reports, have a note about GAForFlash not working.
hi,
i found the same issue, i use fb4.7 and release ios app.(doesn't use adt tool),if i don't add param -useLegacyAOT yes, the app will crash on phone.(with air15.0.302 release).i found maybe Sound.play crash app.When i add -useLegacyAOT yes,it will run well,but package time is too long.
