2
Pattern Maker in Photoshop CC?
Feb 02, 2014 Feb 02, 2014
Does anyone know if the pattern maker filter plug-in is available for CC, and if so where to find it? I did a search on the Adobe site and could only find info on downloading the pattern maker filter plug-in for CS6.
24.6K
LEGEND , Jan 08, 2018 Jan 08, 2018
The only way I can think of at the moment from Photoshop is Filter>Other...>Offset
This will shift the document by # of pixels you specify (Usually 1/2 of total for width and 1/2 for total of height) This will place the edges of the image in the dead center so you can blend the edges, then you can shift back if you choose (Not required) as at this point the entire image would be repeatable.
Now you can define as a pattern - Edit>Define Pattern
This pattern can now be used as a fill or style pattern
Adobe
Unfortunatly, the adobe pattern maker plugin won't work in photoshop cc
There are the scripted pattern features in 14.2.  I don't knoe exactly what Pattern Maker could do, but the 14.2 tools are impressive.
http://tv.adobe.com/watch/creative-cloud-for-photographers/hidden-gems-in-photoshop-cc-142/
Trevor, the pattern maker is for Illustrator, and it's pretty impressive for creating dynamic patterns that can be changed easily.  The scripted fill in PS can actually do many things the pattern maker can't, but it isn't dynamic like the pattern maker.
Feb 03, 2014 Feb 03, 2014
Hello!
In fact there used to be a photoshop plug-in called pattern maker, it was not ported to 64 bits, and the last compatible version seems to be CS5: http://helpx.adobe.com/en/photoshop/using/generate-pattern-using-pattern-maker.html
You will find some videos talking about it if you google for the terms.
A replacement using the new content aware algorithms would be welcome.
Dec 19, 2016 Dec 19, 2016
I agree. A replacement please Adobe.
Do you have Illustrator, its pattern making capabilities is pretty decent.
I do have Illustrator, but also CC version. No Patternmaker there, right?
Sure you can make patterns directly in Illustrator CC.
A quick example...
Guest
i dont use Illustrator CC, i need patter maker in Photoshop CC
This pattern can now be used as a fill or style pattern. or Saving the document it self can be used a repeatable pattern in another program.
You might try this plugin/extension.
the-orange-box.com | Free Seamless Texture Generator
Aug 10, 2018 Aug 10, 2018
Thank you for this!
Contributor ,
Jan 14, 2018 Jan 14, 2018
It's a drag for those who used Photoshop designing textile, like myself. And with the advent of Dye Sublimation, the feature would be greatly useful today.
Photoshop does have the feature to create pattern fills. However, It's limited to square mosaic tiling. No hex or offset tiling.
Open your square tile object
Select it
Edit menu -> Define Pattern
Make a new file with the dimensions you want to fill.
Use the 'pattern' fill effect in adjustment layer menu.
Select your saved pattern.
vuala
