I´m testing Robohelp 10 with SharePoint 365.
I configure the Robohelp and SharePoint as the page: http://help.adobe.com/en_US/RoboHelp/10.0/RoboHTML/WS1b49059a33f77726-5aab66613798e5ec9b-8000.html
On step 3, when I click on "File/Version Control/Add Version Control" and inform "SharePoint Site", user name and password, Robohelp display a message: "Error: The remote server returned an error: (403) Forbidden."
Anybody knows something about this error?
Thanks very much.
Luiza.
First off, I'm not sure whether RH works with SharePoint 365. I know it
works with 2013, so I'm hoping 365 works as well.
Having said that, when you created the connection to SharePoint, what
credentials did you use? If SharePoint uses a different login than your
Windows account, you must specify your credentials.
Kind regards,
Willam
Hi William. Thank you very much.
About my credentials, yes, I used the credentials that I use to access the SharePoint site directly. I didn't use "windows authentication". Besides, I use an administrator password.
I searched and not found anything about the compatible version of SharePoint. The documents show only SharePoint...
Kind regards,
Luiza.
Officially, it's only SP 2007 and 2010. It works on 2013, but that's not
officially supported on RH10.
When you set up the connection, did the test work correctly?
Kind regards,
Willam
Hi Willam!
No. The test is not finished.
(403) Forbidden."
I will test again.
Kind regards,
Luiza.
Luiza Albano
documentacaodesistemas.com.br <http://www.documentacaodesistemas.com.br>
Perfil no Linkedin<http://linkedin.com/profile/view?id=50672818&goback=%2Ewvp_1_1_*1&trk=tab_pro>
Skype: lfalbano
11 99782-6707
2014-03-05 7:57 GMT-03:00 Willam van Weelden <forums_noreply@adobe.com>:
Re: Robohelp 10 and SharePoint 365 created by Willam van Weelden<http://forums.adobe.com/people/WillamvanWeelden>in
RoboHelp - View the full discussion<http://forums.adobe.com/message/6180710#6180710
There can be two issues:
RoboHelp does not support SP 360.
Your SharePoint 365 configuration doesn't allow other programs to
use it's API. Please check with your friendly neighbourhood
SharePoint guru whether this may be the case.
Kind regards,
Willam
Did you ever find out if RH10 is compatible with SP 365 or not? I'm thinking of trying to do what you describe, but I figured I'd see if you ever got your answer!
