Hello
I am intending to buy this laptop
Processor Name | Intel® Core™ i5-4200U Processor 1.60 GHz with Turbo Boost up to 2.60 GHz*1 |
Pre-installed/Max | 4 GB (4 GB (PC3L-12800 SO-DIMM) x 1) DDR3L SDRAM (Max)*2 |
Memory Speed | 1600 MT/s |
Graphics Accelerator | Intel® HD Graphics 4400 |
am I going to get a good performance if used premiere, after effect or photoshop? And notice I said good I do not need it to be rapid fast neither extreme slow.
Also, I already have 5145 1gb ati which was released in 2010 and I am having a pleasant performance, will I get more, same or less with intel 4400 hd graphics card?
Best
Adil
If all you edit is SD (Standard Definition) you will get slow-to-medium... if you try and edit HD you will get slow
Laptop Video Editing PC - http://forums.adobe.com/thread/1369220?tstart=0
Better correct that to:
If all you edit is SD (Standard Definition) you will get slow-to-medium SLOW... if you try and edit HD you will get VERY, VERY AGONIZING slow
All you need is a better CPU, more memory and better disks (plural).
[Moved to Hardware forum.]
I suggest you get a laptop with Nvidia graphics for Premiere. The graphics would have little effect on AE. However since AE performance is CPU and ram that would not be a good config for AE. A quad mobile would still have some limitation in AE but be far better than that config. I would suggest atleast the 4700MQ and 16GB of ram.
Eric
ADK
