I am thankful for this answer as it has partially solved my problem.
when I go here:
cgi.auth_user is populated and the page opens normal
But, when I go here:
http://localhost/dir/index.cfm
I get an HTTP Error 401.2
Basically, it seems the directory level is set up and working, but the file level is not. I double checked that the file level security was set up the same as the directory security(like above) in IIS manager. Anytime I try a file level url, I get the HTTP Error 401.2
Any ideas?
Make sure that index.cfm is defined in your default documents for that IIS site. If that doesn't help, take a look at this thread from the IIS forums to see if any of it applies.
-Carl V.
Carl,
The link you provide does not directly address my issue, but I will post my question to that forum. If I can get this solved I will post the solution here.
Wannab0133,
If I were you, I would create a new thread, rather than continue this old one. 7 years is a very long time in software development. Starting a new thread has the advantage of putting the reader in here-and-now mode.
This issue has been resolved. I followed the steps in this thread:
http://forums.adobe.com/message/4537316
I had to check windows authentication in the server level, then remove anon in the site level.
Thanks for everyone's help.
