copy a movieclip
Apr 15, 2014 Apr 15, 2014
hi,
I wanna have the same function of movieclip running next to the same one.How can I do that?
this is my code:
import flash.display.Graphics; import flash.display.MovieClip; import flash.events.Event; import flash.events.TimerEvent; import flash.utils.Timer;     var objectSpawner:Timer; var fallers:Array; initGame();     function initGame():void {           fallers = [];           objectSpawner = new Timer(1000);           objectSpawner.addEventListener(TimerEvent.TIMER, createEnemy);           objectSpawner.start();           addEventListener(Event.ENTER_FRAME, dropEnemies); }     function createEnemy(e:TimerEvent):void {           var enemy:Faller = new Faller();           enemy.y = -stage.stageHeight;           enemy.x = Math.random() * 380;           MovieClip(enemy).cacheAsBitmap = true;           addChild(enemy);           fallers.push(enemy);           drawConnectors(); }     function dropEnemies(e:Event):void {           trace(fallers.length);           for each (var mc:Faller in fallers)           {                     mc.y += 10;                     if (mc.y > stage.stageHeight * 2)                               fallers.splice(fallers.indexOf(removeChild(mc)), 1);           }           drawConnectors(); }     function drawConnectors():void {           if (fallers.length == 0)                     return;           var g:Graphics = this.graphics;           g.clear();           g.lineStyle(1);           var mc:Faller = fallers[0];           g.moveTo(mc.x, mc.y);           for each (mc in fallers)                     g.lineTo(mc.x, mc.y);     }
ActionScript
719
LEGEND , Apr 15, 2014 Apr 15, 2014
Generally speaking, there is no a streamlined way to literally duplicate instances. So, to create a "duplicate" you should create another instance of the same class.
The code below does that - it creates two instance of the same class that (the class) implements your functionality
Logic that accomplishes the functionality of falling object is now encapsulated into a special class FallingThings. Place this class into the same directory where you FLA. To create class (if you don't know yet how it is
you want what?
This movieclip is running on the left side of my screen and I want the same one to run on the right
if you mean Faller class instances are appearing on the left side of your screen and you want that to change, adjust this line of code:
no , what I want is to have 2 Faller on the screen. 1 on the left side and 1 on the right.
then use:
function createEnemy(e: TimerEvent): void {
    var enemy: Faller = new Faller();
    enemy.y = -stage.stageHeight;  //<-this looks screwy
    enemy.x = Math.random() * stage.stageWidth/2;
    addChild(enemy);
    var enemy1: Faller = new Faller();
    enemy1.y = -stage.stageHeight;  //<-this looks screwy
    enemy1.x = stage.stageWidth/2+Math.random() * stage.stageWidth/2;
  addChild(enemy1);
    fallers.push(enemy1);
    drawConnectors();
Logic that accomplishes the functionality of falling object is now encapsulated into a special class FallingThings. Place this class into the same directory where you FLA. To create class (if you don't know yet how it is done):
1. Create a files in the same directory as you FLA.
2. Name this file FallingThings.as.
3. Paste the code below into this file.
On the main timeline place this code:
init();
function init():void
          var fallingThingsLeft:FallingThings = new FallingThings(stage.stageWidth / 2, stage.stageHeight);
          var fallingThingsRight:FallingThings = new FallingThings(stage.stageWidth / 2, stage.stageHeight);
          addChild(fallingThingsLeft);
          addChild(fallingThingsRight);
          fallingThingsRight.x = stage.stageWidth / 2;
Class:
package
          import flash.display.Sprite;
          public class FallingThings extends Sprite
                    // set width
                    private var w:Number = 0;
                    // set height
                    private var h:Number = 0;
                    private var objectSpawner:Timer;
                    private var fallers:Array;
                    private var speed:Number = 10;
                    public function FallingThings(w:Number, h:Number)
                              this.w = w;
                              this.h = h;
                              init();
                    private function init():void
                              fallers = [];
                    private function createEnemy(e:TimerEvent):void
                              enemy.y = -h;
                              enemy.x = Math.random() * w;
                              addChild(enemy);
                              drawConnectors();
                    private function dropEnemies(e:Event):void
                                        mc.y += speed;
                                        if (mc.y > h * 2)
                              drawConnectors();
                    private function drawConnectors():void
                                        return;
                              g.clear();
                              g.lineStyle(1);
Apr 16, 2014 Apr 16, 2014
You are a BOSS Andrei!
thank you so much
Apr 17, 2014 Apr 17, 2014
I`ve got a last question when I hiTestObject with this code:
this.addEventListener( Event.ENTER_FRAME, handleCollision)
function handleCollision( e:Event ):void {
if (fallingThingsLeft.hitTestObject(Touch1)) {
score_txt.text = "HIT" }
else {
score_txt.text = "MISS" } }
It looks like it works but it tells me "HIT" like 3 sec before it really hit
And thanks again for all your help
