When printing 11x17pages, only half the page is printing. The first page prints fine, but from the second page onwards only half the page is printing.
Please provide more information as to what version of Acrobat and what type of printer (brand, model, PostScript or non-PostScript, etc.) you are printing to as well as settings used.
- Dov
I have been running Adobe X for the last 3-4 years, and recently upgraded to Adobe XI Pro (11.0.05). I did not have these problems with Adobe X. I also don't have these problems when I am printing from Adobe Reader X.
When printing from Acrobat, do you select the paper size from the Properties dialog (accessed next to the printer name in the print dialog)? Or are you checking the Choose paper source by PDF page size option?
If the latter, there is a known issue, especially for PDF files with mixed page sizes. If you don't have mixed page sizes, use the Properties dialog to set the paper size through the print driver and see if that fixes the problem.
- Dov
I am choosing paper source by PDF page size option and Actual Size. I usually have several pages that I am printing and cannot select the page size for each page.
Hi Dov,
I have a few other questions and was wondering if you could help me with these issues as well. This is not an Adobe XI problem but Adobe X.
Since we started using Adobe X Standard & Professional a few years ago when we PDF tables from the excel add-in for some users the page sized are really odd (e.g see attached). We have 2 users, both running Adobe X Standard, the one user gets normal page sizes and the other is getting the odd page sizes.
The other question I have is about the Show Stamp Name function in Adobe XI, is there a way to turn this on permanently?
Do you know when the Adobe quarterly update will be available?
Hi, I tried this but it does not resolve the problem. Instead it prints the image on a 11x17 page but it scales down the image to 50% of the page. I installed the 11.0.6 update yesterday and it seems that there is no fix for this yet.
Our office just upgraded and now we are having the same problem as described by the initial concerned customer in NOVEMBER 2013. Now it's August 2014. It should be understandable what this problem is since this is occurring with several people and Dov has apparently been given several examples.
Our company just purchased five new suites and I"m going to have to take my work home because I have Adobe Acrobat professional VERSION 9 that works better than this,
Version 9 works, this version doesn't.
Hey Dov, what have you been doing - running for Congress? THIS IS DISFUNCTIONAL.
Our company has been faced with the same issue. The first page of a multiple PDF prints fine but all other pages subsequently print on half the page and shrunk down and rotated. The only solution we have found was to print one page at a time. However this is very time consuming. We have had to revert back Adobe Acrobat X until this issue is resolved. An answer from Adobe support would be helpful. We have multiple models of Canon printers and Sharp Printers and it occurs on all of them.
Can you please share any PDF with which you are facing the issue. You may share the file here https://files.acrobat.com or at any location of your preference.
Additionally, it would help in isolating the issue if you could share the make of your printer and whether you are using PCL or PS driver.
Thanks.
I attached a copy of PDF and a scan of the printing result so that you can see what happens. I am printing to a Xerox 7435 colour printer. I don't have this problem when I open the PDF with Reader. Dov Isaacs indicated that this is an Acrobat X Pro issue and nothing do do wiht the printer. Also, occasionally when I print, the first page are rotated 180 degrees which is a real pain when printing 2-sided.
Hi RVD123,
Where have you shared the file?
Here is the link to the shared files: https://files.acrobat.com/#folder/9c0541d2-6fa5-438e-a286-29f8ac40bd2c
Ronel Colkett
[moderator deleted private data]
I am getting error that file has been deleted or moved to another session. can you mail it to me at [moderator deleted e-mail]
Same problem, PDF file w/ mixed originals 8.5x11 & 11x17, opened in Acrobat XI Pro. The 8.5x11's print correct as does the first 11x17, all subsequent 11x17's print off to the lower right hand corner on the 11x17 sheet. Tried on multiple printers with same result. THEN, print the same file via Acrobat IX and it prints all pages correctly.
It seems to be an Acrobat XI problem and nothing do do with the printer. A quick work around is to open the PDF with Adobe Reader X before printing.
Can Reader X be installed on a box running Acrobat XI ?
Apparantly it can cause some problems and is not recommended by Adobe, but it has been working fine for me.
^To answer my own question, why yes, yes it can ^
If this is still an issue for anyone, I've been able to work around this by turing on "print as image" under advanced options in the print dialog box. 11x17 PDFs now print all pages properly instead of just the first one.
Is anyone still having problems with this? I was pretty sure that the problem was resolved with the last update Adobe 11.0.07 but printing today I am having the same problem yet again.
Yes we are having the same issue Adobe Acrobat XI Version 11.0.06
One big issue is we really want to use the PS driver for the printer (prints greyscale for autocad way better)
Here are some specs on what we do and what happens
Pdf- all 11x17 pages created from Civil 3d 2014 (3 pages in this case)
Printer-Ricoh MP 3501 printer
Printer Driver- PS Driver
Settings- Actual Size Checked
Choose Paper Source by pdf page size
Orientation Auto-Portrait/Landscape
What happens,
First page gets rotated 180 degrees (upside down)
Next 2 pages get printed correct orientation (not flipped 180) but are shifted 5-6 inches down and to the left (cutting off a large portion of the page)
How to fix?
All same settings with PCL driver
Prints correct.
This is for pages that have only 1 page size. we have also had issues with printing multiple page sizes.
Have you installed the latest update? Version 11.0.7 is available.
No, company admin thing did that fix it for you?
