i |
This is the code of my img slider, but the counter starts at 0/8 and the next/prev doesn't work. What am I missing?
import fl.containers.UILoader;
//Declaring Variables
var menu:MovieClip = menuMc;
var prevBtn:MovieClip = menuMc.prevBtnMc;
var nextBtn:MovieClip = menuMc.nextBtnMc;
var playBtn:MovieClip = menuMc.playBtnMc;
var stopBtn:MovieClip = menuMc.stopBtnMc;
var imgFolder:String = "imgs/"
var imgArray:Array = new Array("1.jpg","2.jpg","3.jpg","4.jpg","5.jpg","6.jpg","7.jpg","8.jpg");
var imgLoader:UILoader = imgLoader;
var imgCntr:uint = 0;
var imgCntrTotal:uint = imgArray.length;
var imgRequest:URLRequest = new URLRequest(imgFolder + imgArray[imgCntr]);
var imgCntrTxt:TextField = menu.imgCntrTxtTf;
var slideShowTimer:Timer = new Timer (5000,0);
var imgVisible:Boolean = true;
//Init
nextBtn.stop();
prevBtn.stop();
playBtn.stop();
stopBtn.stop();
imgLoader.load(imgRequest);
imgCntrTxt.text = (imgCntr).toString() + "/" + imgArray.length.toString();
//Events
//Play
playBtn.addEventListener(MouseEvent.MOUSE_DOWN,playBtnDown);
playBtn.addEventListener(MouseEvent.MOUSE_OVER,playBtnOver);
playBtn.addEventListener(MouseEvent.MOUSE_OUT,playBtnOut);
//Stop
stopBtn.addEventListener(MouseEvent.MOUSE_DOWN,stopBtnDown);
stopBtn.addEventListener(MouseEvent.MOUSE_OVER,stopBtnOver);
stopBtn.addEventListener(MouseEvent.MOUSE_OUT,stopBtnOut);
//Timer
slideShowTimer.addEventListener(TimerEvent.TIMER,timePassed);
//EventHandlers
//Play
function playBtnOver(e:MouseEvent){
playBtn.gotoAndStop(2);
function playBtnOut(e:MouseEvent){
playBtn.gotoAndStop(1);
function playBtnDown(e:MouseEvent){
//Slideshow / Timer starten
slideShowTimer.start();
//Stop
function stopBtnOver(e:MouseEvent){
stopBtn.gotoAndStop(2);
function stopBtnOut(e:MouseEvent){
stopBtn.gotoAndStop(1);
function stopBtnDown(e:MouseEvent){
// Slideshow / Timer Stoppen
slideShowTimer.stop();
//SlideShowTimer
function timePassed(e:TimerEvent){
imgLoader.addEventListener(Event.ENTER_FRAME,fadeImg);
//Functions
function fadeImg(e:Event){
if(imgVisible == true){
imgLoader.alpha = imgLoader.alpha - 0.05;
if(imgLoader.alpha <= 0){
imgVisible = false;
nextImg();
if(imgVisible == false){
imgLoader.alpha = imgLoader.alpha + 0.05;
if(imgLoader.alpha >= 1){
imgVisible = true;
imgLoader.removeEventListener(Event.ENTER_FRAME,fadeImg);
function nextImg(){
if(imgCntr < imgCntrTotal){
imgCntr++; //staat gelijk aan imgCntr + 1
}else{
imgCntr = 0;
imgRequest = new URLRequest(imgFolder + imgArray[imgCntr]);
imgCntrTxt.text = imgCntr.toString() + "/" + imgCntrTotal.toString();
function tfF():void{
imgCntrTxt.text = (imgCntr+1) + "/" + (imgCntrTotal);
Help is appreciated,
gr, Matthijs
As far as starting at 0, that is likely becaiusew you set it to start at zero and don't increment the counter until after you are loading the second image. Try incrementing it when you load the first image. You might need to not set it back to 0 either when you reach the end if the intention is to loop... when you reach the end you should go back to 1, not 0.
You don't appear to have any event listeners for the previous and next buttons, so that might be the reason they don't work.
