Hello Awesome Adobe Community,
I have an application that loads over 2000 external SWFs with probably about a third of them with actionscript byte code (ABC). When I package the app using ipa-debug, the external stripped SWFs work just fine. When I package a release build with ipa-app-store or ipa-ad-hoc the external SWFs do not work and they freeze the app when the asctionscript is supposed to run (a typical crash when loading uncompiled ABC).
I've already looked at a lot of possible causes and checked them, but most of these problems would break it in debug anyways.
I have been searching and searching and can't find anything to help me. Apple already approved my app (can't believe they let this slip by) and it is sitting on the App Store broken. Please help me!!!
Hi k_bitgood,
Can you please try your app with latest AIR 13 beta with SWF-version =24, if you still face the issue then please share a sample app(sources, swfs, app-xml and assets) with us at nimisha1@adobe.com?
-Nimisha
Hi Nimisha,
I sent you an email (same subject as this discussion) from k******* [at] onlineschool [dot] ca with a sample app. Please let me know if you need anything else or if you find a solution.
Kenneth
