Hi there
I'm using Captivate 6 and for some reason, when reviewing the quiz, I can't see the 'correct' and 'incorrect' images showing which answers the user got right / wrong.
I've checked the settings and everything appears to be the same as previous projects. Can you tell me if this is a bug or is there something I may be missing?
Cheers
Julie
Update - I think it must have been a little bug. I sorted it now. In case anyone has the same issue what I did was remove the option for users to review the quiz and save the project and close Captivate. Restart Captivate, open the project and then add in the option to review and save. That did the trick.
Try clearing your project cache (Preferences > General > Clear Cache button) and then publish again.
Hi Rod
I'll try that next time if it happens again.
I sorted it now. I did removed the option for users to review the quiz and save the project and close Captivate. Restart Captivate, open the project and then add in the option to review and save. That did the trick.
Cheers
Julie
I'm having this exact same problem, however it works in HTML5. Only Flash publications won't show the review checkmarks and Xs. Any thoughts?
