Hello, for some reason, captivate 7 is not allowing me the option to select the HTML5 checkbox option so I can publish my file in the HTML5 format. I selected the HTML5 tracker, and it showed no conflicts. Please let me know what I need to do so I can publish these files in HTML5, thanks......
Hello,
Welcome to Adobe Forums.
Does it happen with a blank project as well ?
If you have a quiz, which reporting feature you are using ?
Vikram Gaur
Adobe Support
Hi Vikram, I am reporting to adobe.com, and i am reporting "points" not "percentages". It don't have this issue with a blank project, the html check box is avialible. Also, when I publish the file in a .swf, the output folder does contain an html file, not sure if it does this by default, but, I am trying to publish solely in the Html 5 format, but this option is unfortanetely "grayed" out. The file I am trying to publish conatins multiple drag and drop slides, but, according to what i have read, this shouldn't be an issue. Thanks again....John
HTML5 does not support Reporting to "Acrobat.com"
You may publish SWF or use another reporting option in HTML5
Note : While publishing SWF, make sure "Zip Files" is unchecked.
Vikram
okay thanks Vikram, I think that is my problem. Do u know if the html 5 output supports reporting to the blackboard LMS server by any chance?
Sent via the Samsung Galaxy Note® 3, an AT&T 4G LTE smartphone,
If Blackboard LMS is a SCORM LMS, then reporting of HTML5 will work.
Vikram
