Can i change the text of the submit button in the login box of a secure zone?
Or, maybe, i can replace the button with the image?
So, can this be done, and how to achieve this?
Any suggestions are welcome.
Hi there,
It is a web form button in html
You can do what you like with it really and you can google the basics of CSS, HTML and Forms if you need help on that.
- A form input button can be styled as you want and you can change the value which is the wording to what you want.
- You can change input to a button, style that and have text/html inside the element tags.
- You can change it to an image type submit input.
Ok, this is the description:
http://helpx.adobe.com/business-catalyst/partner/add-secure-area-your-site.html
"You can replace the form submit button with an image by clicking the Use Image Form Button."
Can please anyone tell me where can i find this "Use Image Form Button"?
Message was edited by: ChefEng
Hi there,
Thank you for clearing this out Liam Dilley, you saved me a lot of time.
My bad, i thought that i can't neither change the value nor the type of it. Tested it with incorrect login credentials by mistake.
Have another question related to this:
Can you then suggest how should i customize the log out link of module_logout? Change the text of it.
Thanks in advance.
