I have installed PS CC on 2 Max's with the same result on both
The splash screen shows, the app opens for a couple of seconds then closes
There is no error reported and I can not find an issue in a log.
I have followed a multitude of information on discussion boards but to no avail
Where should I start looking?
I have Light Room 5 and PS CS6 installed and have no issue with them
Thanks for the help
Regards
Ross
Please navigate to Library/Application Support/Adobe/SLCache and rename it. Launch CC app's, sign in and let us know if still the same issue.
Romit Sinha
That sounds like your subscription information is invalid, and it's closing as if you had stopped the subscription.
Hi Chris,
Thanks for the reply, I have been over the subscription information it all looks ok.
I took out the "Photoshop Photography Program" The information and my profile appears valid and the invoice is showing the payment went thru ok.
When the chat comes back on line I will get in contact and see if it all ok from Adobe's end.
Any other ideas where I could look?
Ross
Hi Ross Hage,
Do you have any other application apart from CC installed on your machine? Which OS are you using?
Romit Sinha
Hi Romit
I have installed;
Ableton Live 9
Lightroom 5
Photoshop CS6
Trend Micro AV (had it turned off during the install)
Pages, Numbers, Keynote
iBank
The OS version is OS X 10.9.2 (13C64)
Regards
Ross
Romit Sinha
Hi Romit,
Thanks very much, it now works like a treat
Regards
Ross
