I just started ramping on Flex and CF.
I was working through the FlexTestDrive but am getting stuck at the same place on two different machines using WinXP, IE8, CF9 and FB 4.5 on a laptop and WinXP, IE8, CF10 and FB4.5 on a desktop.
Up to the point where I am adding data to the db provided by Adobe everything works fine.
Module 2 - Add Data
I get an error popup that says:
Unable to invoke CFC - Error Executing Database Query.
Java exception: 'Negative position: java.lang.IllegalArgumentException'.
Has anybody reached that position and had this issue.
Couldn't find anything similar on the forums or on Google.
Thanks.
I experimented the same issue while developing the FlexWebTestDrive tutorial step by step. I reviewed the CF service classes, parameters and the click handler event but everything was correct, so I've found this could be due to the ColdFusion server settings but not pretty sure. Have you ever solved this issue?
Regards
