I am getting error 1009 on a simple game i have made using actionscript 3 and have no idea how to fix it, can someone help me? Please!!!
scene 1- menu frame 1-
stop();
stage.removeEventListener(Event.ENTER_FRAME, Walk);
stage.removeEventListener(Event.ENTER_FRAME, Caught);
function go(Event:MouseEvent){
gotoAndPlay(2);
start.addEventListener(MouseEvent.CLICK, go);
Scene 1 script frame 2
stop();
stage.addEventListener(KeyboardEvent.KEY_DOWN, KeyPress);
stage.addEventListener(KeyboardEvent.KEY_UP, KeyRelease);
stage.addEventListener(Event.ENTER_FRAME, Walk);
stage.addEventListener(Event.ENTER_FRAME, Caught);
stage.addEventListener(Event.ENTER_FRAME, Caught2);
stage.addEventListener(Event.ENTER_FRAME, Caught3);
stage.addEventListener(Event.ENTER_FRAME, Caught4);
stage.addEventListener(Event.ENTER_FRAME, Caught5);
var vDirection = "Null"
var vStuff = 0
function KeyPress(event:KeyboardEvent){
if(event.keyCode == 39){
vDirection = "Right";
if(event.keyCode == 37){
vDirection = "Left";
if(event.keyCode == 38){
vDirection = "Up";
if(event.keyCode == 40){
vDirection = "Down";
function KeyRelease(event:KeyboardEvent){
vDirection = "Null";
function Walk(event:Event){
if(vDirection == "Right"){
if(Walls.hitTestPoint(Player.x + Player.RightTargetMC.x, Player.y + Player.RightTargetMC.y, true)){
}else{
Walls.x = Walls.x - 10;
SecurityGuards.x = SecurityGuards.x - 10;
Smyth.x = Smyth.x - 10;
Stanley.x = Stanley.x - 10;
if(vDirection == "Left"){
if(Walls.hitTestPoint(Player.x + Player.LeftTargetMC.x, Player.y + Player.LeftTargetMC.y, true)){
}else{
Walls.x = Walls.x + 10;
SecurityGuards.x = SecurityGuards.x + 10;
Smyth.x = Smyth.x + 10;
Stanley.x = Stanley.x + 10;
if(vDirection == "Up"){
if(Walls.hitTestPoint(Player.x + Player.TopTargetMC.x, Player.y + Player.TopTargetMC.y, true)){
}else{
Walls.y = Walls.y + 10;
SecurityGuards.y = SecurityGuards.y + 10;
Smyth.y = Smyth.y + 10;
Stanley.y = Stanley.y + 10;
if(vDirection == "Down"){
if(Walls.hitTestPoint(Player.x + Player.BottomTargetMC.x, Player.y + Player.BottomTargetMC.y, true)){
}else{
Walls.y = Walls.y - 10;
SecurityGuards.y = SecurityGuards.y - 10;
Smyth.y = Smyth.y - 10;
Stanley.y = Stanley.y - 10;
function Caught(event:Event){
if(Player.hitTestObject(SecurityGuards.SG1)){
this.gotoAndStop(3);
function Caught2(event:Event){
if(Player.hitTestObject(SecurityGuards.SG2)){
function Caught3(event:Event){
if(Player.hitTestObject(SecurityGuards.SG3)){
function Caught4(event:Event){
if(Player.hitTestObject(SecurityGuards.SG4)){
function Caught5(event:Event){
if(Player.hitTestObject(SecurityGuards.SG5)){
var vKey = 0;
StanleyCupMC.stop();
function getout(event:MouseEvent){
if (vKey == 1){
gotoAndStop(4);
function pickupscup(event:MouseEvent){
Stanley.gotoAndStop(2);
vKey = 1;
StanleyCupMC.StanleyCup.addEventListener(MouseEvent.CLICK, pickupscup);
out.addEventListener(MouseEvent.CLICK, getout);
scene 1- script frame 3
stop();
function ta(Event:MouseEvent){
gotoAndStop(2);
tryagain.addEventListener(MouseEvent.CLICK, ta);
scene 1 script frame 4
stop();
function pa(Event:MouseEvent){
gotoAndStop(2);
playagain.addEventListener(MouseEvent.CLICK, pa);
click file>publish settings>swf and tick 'permit debugging'. retest.
the error message will contain the frame/layer and line number of the problematic code. if that doesn't allow you to quickly correct your error copy and paste the complete error message and indicate the problematic line of code.
i do not see permit debugging, under publish settings. also when i click the debug under the debug window the program crashes?? I am using flash cc
attach a screenshot of the publish settings panel after clicking file>publish settings>swf, http://forums.adobe.com/message/4209263#4209263
i found the publish setting- once i check that, do I click ok or publish? then do i go to control test?
this is what the output window says
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at BostickCupGame_fla::MainTimeline/frame2()[BostickCupGame_fla.MainTimeline::frame2:120]
at flash.display::Sprite/constructChildren()
at flash.display::Sprite()
at flash.display::MovieClip()
at BostickCupGame_fla::StanleyCupMC_7()
at flash.display::MovieClip/gotoAndPlay()
at BostickCupGame_fla::MainTimeline/go()[BostickCupGame_fla.MainTimeline::frame1:6]
what's line 120 of frame 2?
this is the problem report from flash crashjing upon using the debug mode.
Process: Flash Player Debugger [91707]
Path: /Applications/Adobe Flash CC/*/Flash Player Debugger.app/Contents/MacOS/Flash Player Debugger
Identifier: com.macromedia.Flash Player Debugger.app
Version: 11.8.800.176 (11.8.800.176)
Code Type: X86-64 (Native)
Parent Process: launchd [352]
Responsible: Flash Player Debugger [91707]
User ID: 501
Date/Time: 2014-04-20 14:56:26.626 -0400
OS Version: Mac OS X 10.9.2 (13C64)
Report Version: 11
Anonymous UUID: 82B95BBB-3A97-553B-1455-98481B1B4518
Sleep/Wake UUID: F5DCD2FC-1C46-483D-B7C4-6EC4C4A0EE70
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '*** -[NSKeyedUnarchiver initForReadingWithData:]: incomprehensible archive (0x62, 0x70, 0x6c, 0x69, 0x73, 0x74, 0x30, 0x30)'
abort() called
terminating with uncaught exception of type NSException
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fff8c29c25c __exceptionPreprocess + 172
1 libobjc.A.dylib 0x00007fff8d824e75 objc_exception_throw + 43
2 CoreFoundation 0x00007fff8c29c10c +[NSException raise:format:] + 204
3 Foundation 0x00007fff89dd4087 -[NSKeyedUnarchiver initForReadingWithData:] + 3055
4 AppKit 0x00007fff869a36b2 loadNib + 155
5 AppKit 0x00007fff869a2cfc +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 288
6 AppKit 0x00007fff86c37542 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 140
7 AppKit 0x00007fff869a29d3 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 605
8 AppKit 0x00007fff8699e727 NSApplicationMain + 448
9 Flash Player Debugger 0x0000000100014de0 Flash Player Debugger + 85472
10 ??? 0x0000000000000001 0x0 + 1
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff88140866 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff8e07035c pthread_kill + 92
2 libsystem_c.dylib 0x00007fff8e56db1a abort + 125
3 libc++abi.dylib 0x00007fff92aebf31 abort_message + 257
4 libc++abi.dylib 0x00007fff92b11952 default_terminate_handler() + 264
5 libobjc.A.dylib 0x00007fff8d82530d _objc_terminate() + 103
6 libc++abi.dylib 0x00007fff92b0f1d1 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fff92b0ec5b __cxa_throw + 124
8 libobjc.A.dylib 0x00007fff8d824fa1 objc_exception_throw + 343
9 com.apple.CoreFoundation 0x00007fff8c29c10c +[NSException raise:format:] + 204
10 com.apple.Foundation 0x00007fff89dd4087 -[NSKeyedUnarchiver initForReadingWithData:] + 3055
11 com.apple.AppKit 0x00007fff869a36b2 loadNib + 155
12 com.apple.AppKit 0x00007fff869a2cfc +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 288
13 com.apple.AppKit 0x00007fff86c37542 +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 140
14 com.apple.AppKit 0x00007fff869a29d3 +[NSBundle(NSNibLoading) loadNibNamed:owner:] + 605
15 com.apple.AppKit 0x00007fff8699e727 NSApplicationMain + 448
16 com.macromedia.Flash Player Debugger.app 0x0000000100014de0 0x100000000 + 85472
Thread 1:
0 libsystem_kernel.dylib 0x00007fff88140e6a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8e070f08 _pthread_wqthread + 330
2 libsystem_pthread.dylib 0x00007fff8e073fb9 start_wqthread + 13
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff88141662 kevent64 + 10
1 libdispatch.dylib 0x00007fff919f243d _dispatch_mgr_invoke + 239
2 libdispatch.dylib 0x00007fff919f2152 _dispatch_mgr_thread + 52
Thread 3:
Thread 4:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fff781d0310 rcx: 0x00007fff5fbfe078 rdx: 0x0000000000000000
rdi: 0x0000000000000707 rsi: 0x0000000000000006 rbp: 0x00007fff5fbfe0a0 rsp: 0x00007fff5fbfe078
r8: 0x00007fff92b12959 r9: 0x00007fff8e5958d0 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x00007fff5fbfe200 r13: 0x0000610000130958 r14: 0x0000000000000006 r15: 0x00007fff5fbfe0e0
rip: 0x00007fff88140866 rfl: 0x0000000000000206 cr2: 0x0000000102b8e000
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x100000000 - 0x1013ddfd7 +com.macromedia.Flash Player Debugger.app (11.8.800.176 - 11.8.800.176) <4C4B7314-0E88-0F4E-35ED-4408DB618B71> /Applications/Adobe Flash CC/*/Flash Player Debugger.app/Contents/MacOS/Flash Player Debugger
0x101619000 - 0x10161dfff com.apple.agl (3.2.3 - AGL-3.2.3) <1B85306F-D2BF-3FE3-9915-165237B491EB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff6e065000 - 0x7fff6e098817 dyld (239.4) <2B17750C-ED1B-3060-B64E-21897D08B28B> /usr/lib/dyld
0x7fff8689b000 - 0x7fff868ecff3 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <BF4C2FE3-8BC8-30D1-8347-2A7221268794> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff868ed000 - 0x7fff868efff3 libsystem_configuration.dylib (596.13) <B51C8C22-C455-36AC-952D-A319B6545884> /usr/lib/system/libsystem_configuration.dylib
0x7fff868f0000 - 0x7fff868f7ff3 libcopyfile.dylib (103) <5A881779-D0D6-3029-B371-E3021C2DDA5E> /usr/lib/system/libcopyfile.dylib
0x7fff868f8000 - 0x7fff86981fff com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8699c000 - 0x7fff87512fff com.apple.AppKit (6.9 - 1265.19) <12647F2F-3FE2-3D77-B3F0-33EFAFF2CEA7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff87513000 - 0x7fff875defff libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8769c000 - 0x7fff876a2ff7 libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib
0x7fff876ca000 - 0x7fff87708ff7 libGLImage.dylib (9.6) <DCF2E131-A65E-33B2-B32D-28FF01605AB1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff87709000 - 0x7fff87770ff7 com.apple.CoreUtils (2.0 - 200.34.4) <E53B97FE-E067-33F6-A9C1-D4EC2A20FB9F> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff87771000 - 0x7fff8777afff com.apple.DisplayServicesFW (2.8 - 360.8.14) <816A9CED-1BC0-3C76-8103-1B9BE0F723BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff8777b000 - 0x7fff87798ff7 com.apple.framework.Apple80211 (9.3.1 - 931.58) <D5B2DD15-3DCC-31F6-9320-3A20A887C5D5> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff880dc000 - 0x7fff8812afff libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
0x7fff8812b000 - 0x7fff88147ff7 libsystem_kernel.dylib (2422.90.20) <20E00C54-9222-359F-BD98-CB79ABED769A> /usr/lib/system/libsystem_kernel.dylib
0x7fff88148000 - 0x7fff881adff5 com.apple.Heimdal (4.0 - 2.0) <523EC6C4-BD9B-3840-9376-E617BA627F59> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff881c5000 - 0x7fff882b6ff9 libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
0x7fff8830f000 - 0x7fff88326ff7 com.apple.CFOpenDirectory (10.9 - 173.90.1) <38A25261-C622-3F11-BFD3-7AFFC44D57B8> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff88327000 - 0x7fff88343fff libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
0x7fff8838f000 - 0x7fff883ddfff com.apple.opencl (2.3.59 - 2.3.59) <8C2ACCC6-B0BA-3FE7-98A1-5C67284DEA4E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff883de000 - 0x7fff88cfdaf3 com.apple.CoreGraphics (1.600.0 - 599.20.11) <06212100-8069-31A1-9C44-F6C4B1695230> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff88cfe000 - 0x7fff89221fff com.apple.QuartzComposer (5.1 - 319) <8B90921F-911B-3240-A1D5-3C084F3E6A36> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff89222000 - 0x7fff894f6fc7 com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff894f7000 - 0x7fff8956efff com.apple.CoreServices.OSServices (600.4 - 600.4) <36B2B009-C35E-3F21-824E-E0D00E7808C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8956f000 - 0x7fff89659fff libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
0x7fff896cf000 - 0x7fff896e0ff7 libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
0x7fff896e1000 - 0x7fff89728fff libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff89756000 - 0x7fff8975dfff com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8975e000 - 0x7fff8975fffb libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
0x7fff89760000 - 0x7fff897adff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff897f4000 - 0x7fff89916ff1 com.apple.avfoundation (2.0 - 651.12) <5261E6EA-7476-32B2-A12A-D42598A9B2EA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff89917000 - 0x7fff8991ffff libsystem_dnssd.dylib (522.90.2) <A0B7CF19-D9F2-33D4-8107-A62184C9066E> /usr/lib/system/libsystem_dnssd.dylib
0x7fff89920000 - 0x7fff89958ff7 com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff89b1e000 - 0x7fff89b1fff7 com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff89b20000 - 0x7fff89b2bff7 com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff89b69000 - 0x7fff89bb2fff com.apple.CoreMedia (1.0 - 1273.49) <D91EC90A-BFF1-300D-A353-68001705811C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff89bb3000 - 0x7fff89c04fff com.apple.QuickLookFramework (5.0 - 622.7) <17685CEC-C94B-3F83-ADE1-B24840B35E44> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff89c05000 - 0x7fff89dbdff3 libicucore.A.dylib (511.31) <167DDD0A-A935-31AF-B5B9-940268EC3A3C> /usr/lib/libicucore.A.dylib
0x7fff89dbe000 - 0x7fff8a0bcfff com.apple.Foundation (6.9 - 1056.13) <2EE9AB07-3EA0-37D3-B407-4A520F2CB497> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8a0bd000 - 0x7fff8a0c2ff7 com.apple.MediaAccessibility (1.0 - 43) <D309D83D-5FAE-37A4-85ED-FFBDA8B66B82> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff8a0c3000 - 0x7fff8a233ff8 com.apple.CFNetwork (673.2.1 - 673.2.1) <AE407146-CCF2-33DD-AAEA-6887FD6F45BA> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8a244000 - 0x7fff8a25cff7 com.apple.GenerationalStorage (2.0 - 160.2) <79629AC7-896F-3302-8AC1-4939020F08C3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff8a25d000 - 0x7fff8a26bfff com.apple.opengl (9.6.0 - 9.6.0) <709F4A02-73A0-303C-86B5-85C596C8B707> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8a426000 - 0x7fff8a430ff7 com.apple.CrashReporterSupport (10.9 - 538) <B487466B-3AA1-3854-A808-A61F049FA794> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8a431000 - 0x7fff8a43afff com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <383FB557-E88E-3239-82B8-15F9F885B702> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8a572000 - 0x7fff8a575ffc com.apple.IOSurface (91 - 91) <07CA8A59-1E32-3FB6-B506-18DAF58A8CE0> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8a598000 - 0x7fff8a607ff1 com.apple.ApplicationServices.ATS (360 - 363.3) <546E89D9-2AE7-3111-B2B8-2366650D22F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8a65c000 - 0x7fff8a66bff8 com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8a66c000 - 0x7fff8a9a2fff com.apple.MediaToolbox (1.0 - 1273.49) <AB8ED666-6D15-3367-A033-F4A8AD33C4E0> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff8a9a3000 - 0x7fff8a9a7fff libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
0x7fff8b9b0000 - 0x7fff8b9b3fff libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8ba48000 - 0x7fff8ba6cfff com.apple.quartzfilters (1.8.0 - 1.7.0) <39C08086-9866-372F-9420-81F5689149DF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff8ba6d000 - 0x7fff8ba75fff libMatch.1.dylib (19) <021293AB-407D-309A-87F5-8E782F46753E> /usr/lib/libMatch.1.dylib
0x7fff8ba76000 - 0x7fff8ba79fff com.apple.AppleSystemInfo (3.0 - 3.0) <61FE171D-3D88-313F-A832-280AEC8F4AB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff8babb000 - 0x7fff8bac6fff libGL.dylib (9.6) <A2EF4E15-EA08-396D-A1D4-29E1CED6876A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8bac7000 - 0x7fff8bb47fff com.apple.CoreSymbolication (3.0 - 141) <B018335C-698B-3F87-AF1C-6115C4FA8954> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8bdda000 - 0x7fff8bdf1ffa libAVFAudio.dylib (32.2) <52DA516B-DE79-322C-9E1B-2658019289D7> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff8bdf2000 - 0x7fff8bdf2fff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8bdf3000 - 0x7fff8bdf7ff7 libsystem_stats.dylib (93.90.3) <1A55AF8A-B6C4-3163-B557-3AD25DA643A8> /usr/lib/system/libsystem_stats.dylib
0x7fff8be2e000 - 0x7fff8be98ff7 com.apple.framework.IOKit (2.0.1 - 907.90.2) <A779DE46-BB7E-36FD-9348-694F9B09718F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8be99000 - 0x7fff8bf80ff7 libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
0x7fff8bfaa000 - 0x7fff8c0daff7 com.apple.desktopservices (1.8.2 - 1.8.2) <76D6ED93-9D5A-3941-8B88-A1773290AE74> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8c14e000 - 0x7fff8c333fff com.apple.CoreFoundation (6.9 - 855.14) <617B8A7B-FAB2-3271-A09B-C542E351C532> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8c334000 - 0x7fff8c380ffe com.apple.CoreMediaIO (407.0 - 4561) <BC8222A6-516C-380C-AB7D-DE78B23574DC> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff8c381000 - 0x7fff8c3d3fff libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
0x7fff8c3d4000 - 0x7fff8c3e5ff7 libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
0x7fff8c479000 - 0x7fff8c8acffb com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff8c8ad000 - 0x7fff8cb97fff com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff8cc4e000 - 0x7fff8cc53fff com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8cc5a000 - 0x7fff8cd9bfff com.apple.QTKit (7.7.3 - 2826.17) <ADA1EF77-57D2-3E7E-8526-8F0B732C1218> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff8cd9c000 - 0x7fff8cd9dff7 libSystem.B.dylib (1197.1.1) <BFC0DC97-46C6-3BE0-9983-54A98734897A> /usr/lib/libSystem.B.dylib
0x7fff8d04a000 - 0x7fff8d074ff7 libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
0x7fff8d075000 - 0x7fff8d07bff7 com.apple.XPCService (2.0 - 1) <2CE632D7-FE57-36CF-91D4-C57D0F2E0BFE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8d07c000 - 0x7fff8d097ff7 libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib
0x7fff8d5d5000 - 0x7fff8d5ddffc libGFXShared.dylib (9.6) <E276D384-3616-3511-B5F2-92621D6372D6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8d5de000 - 0x7fff8d5e5ff8 liblaunch.dylib (842.90.1) <38D1AB2C-A476-385F-8EA8-7AB604CA1F89> /usr/lib/system/liblaunch.dylib
0x7fff8d603000 - 0x7fff8d632fd2 libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
0x7fff8d633000 - 0x7fff8d686fff com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x7fff8d715000 - 0x7fff8d717fff com.apple.Mangrove (1.0 - 1) <72F5CBC7-4E78-374E-98EA-C3700136904E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff8d722000 - 0x7fff8d811fff libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8d817000 - 0x7fff8d9c4f27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
0x7fff8d9c5000 - 0x7fff8dacbff7 com.apple.ImageIO.framework (3.3.0 - 1042) <6101F33E-CACC-3070-960A-9A2EA4BC5F44> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff8dacc000 - 0x7fff8dad5ff3 libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
0x7fff8daee000 - 0x7fff8daf0ff7 libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
0x7fff8daf1000 - 0x7fff8db64fff com.apple.securityfoundation (6.0 - 55122.1) <1939DE0B-BC38-3E50-8A8C-3471C8AC4CD6> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8db65000 - 0x7fff8dba6fff com.apple.PerformanceAnalysis (1.47 - 47) <784ED7B8-FAE4-36CE-8C76-B7D300316C9F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8dba7000 - 0x7fff8dbafff7 com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8dbb0000 - 0x7fff8dbd9fff com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8dbda000 - 0x7fff8dc33fff libTIFF.dylib (1042) <51D02EEC-0D0C-34C1-91C8-D316473A3FEA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8dc34000 - 0x7fff8dcbcff7 com.apple.CorePDF (4.0 - 4) <92D15ED1-D2E1-3ECB-93FF-42888219A99F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8dcbd000 - 0x7fff8dcd6ff7 com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8dcd7000 - 0x7fff8dcfeff7 libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
0x7fff8dcff000 - 0x7fff8dd09ff7 com.apple.AppSandbox (3.0 - 1) <9F27DC25-C566-3AEF-92D3-DCFE7836916D> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff8dd0a000 - 0x7fff8dea6ff3 com.apple.QuartzCore (1.8 - 332.3) <80F1068F-4A34-34FB-9E05-A2DC0700D2F2> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff8dec6000 - 0x7fff8df97fff com.apple.QuickLookUIFramework (5.0 - 622.7) <13841701-34C2-353D-868D-3E08D020C90F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff8df9a000 - 0x7fff8dfb0fff com.apple.CoreMediaAuthoring (2.2 - 947) <B01FBACC-DDD5-30A8-BCCF-57CE24ABA329> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff8dfb1000 - 0x7fff8dfe0ff7 com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <404369C0-ED9F-3010-8D2F-BC55285F7808> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff8dfe1000 - 0x7fff8e06dff7 com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8e06e000 - 0x7fff8e075ff7 libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
0x7fff8e07d000 - 0x7fff8e4cbfff com.apple.VideoToolbox (1.0 - 1273.49) <27177077-9107-3E06-ADAD-92B80E80CDCD> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff8e4cc000 - 0x7fff8e4e7ff7 libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
0x7fff8e4e8000 - 0x7fff8e50cff7 libJPEG.dylib (1042) <33648F26-A1DA-3C30-B15B-E9FFD41DB25C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8e511000 - 0x7fff8e59aff7 libsystem_c.dylib (997.90.3) <6FD3A400-4BB2-3B95-B90C-BE6E9D0D78FA> /usr/lib/system/libsystem_c.dylib
0x7fff8e59b000 - 0x7fff8e5c2ffb libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
0x7fff8e5c3000 - 0x7fff8e5cdfff libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
0x7fff8e8aa000 - 0x7fff8e8aaffd libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
0x7fff8eade000 - 0x7fff8eba0ff5 com.apple.CoreText (352.0 - 367.19) <24848DF1-67EC-3D41-9548-1F14C6DFBBF9> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8ebc8000 - 0x7fff8ebc8ffd com.apple.audio.units.AudioUnit (1.10 - 1.10) <486A97CD-C1F7-324D-87BC-B07F7A415B68> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8ebc9000 - 0x7fff8ec8dff7 com.apple.backup.framework (1.5.2 - 1.5.2) <A3C552F0-670B-388F-93FA-D917F96ACE1B> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8ec8e000 - 0x7fff8ec8efff com.apple.quartzframework (1.5 - 1.5) <3B2A72DB-39FC-3C5B-98BE-605F37777F37> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff8ec8f000 - 0x7fff8ec98ffb com.apple.CommonAuth (4.0 - 2.0) <70FDDA03-7B44-37EC-B78E-3EC3C8505C76> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff8ed2a000 - 0x7fff8ed31fff libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
0x7fff8ed32000 - 0x7fff8ef7aff7 com.apple.CoreData (107 - 481.01) <DA339795-5D97-35B5-9B04-629830013720> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8ef7b000 - 0x7fff8f0e9ff7 libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8f0ea000 - 0x7fff8f0ebff7 libsystem_sandbox.dylib (278.11) <5E5A6E09-33A9-391A-AB34-E57D93BB1551> /usr/lib/system/libsystem_sandbox.dylib
0x7fff8f0ec000 - 0x7fff8f0eeff7 com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8f0f5000 - 0x7fff8f0f7fff libCVMSPluginSupport.dylib (9.6) <FFDA2811-060E-3591-A280-4A726AA82436> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8f0f8000 - 0x7fff8f137fff libGLU.dylib (9.6) <EE4907CA-219C-34BD-A84E-B85695F64C05> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8f138000 - 0x7fff8f28bff7 com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <3511ABFE-22E1-3B91-B86A-5E3A78CE33FD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8f69f000 - 0x7fff8f78dfff libJP2.dylib (1042) <01D988D4-E36F-3120-8BA4-EF6282ECB010> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8f8fd000 - 0x7fff8f901ff7 libGIF.dylib (1042) <C57840F6-1C11-3273-B4FC-956950B94034> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8f902000 - 0x7fff8f903fff liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
0x7fff8f9bd000 - 0x7fff8f9d6ff7 com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff8f9d7000 - 0x7fff8fa87ff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8fa88000 - 0x7fff8fab2ff7 libsandbox.1.dylib (278.11) <9E5654BF-DCD3-3B15-9C63-209B2B2D2803> /usr/lib/libsandbox.1.dylib
0x7fff8fab3000 - 0x7fff8facbff7 com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8facc000 - 0x7fff8fb1aff9 libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
0x7fff8fb1b000 - 0x7fff8fb1ffff com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8fb20000 - 0x7fff8fb48ffb libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
0x7fff8fb4c000 - 0x7fff8fbdcfff com.apple.Metadata (10.7.0 - 800.23) <BFEE576F-D779-300B-B685-26A3A008710A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff8fbdd000 - 0x7fff8fc28fff com.apple.ImageCaptureCore (5.0 - 5.0) <F529EDDC-E2F5-30CA-9938-AF23296B5C5B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff8fc72000 - 0x7fff8fc76ff7 libheimdal-asn1.dylib (323.15) <B8BF2B7D-E913-3544-AA6D-CAC119F81C7C> /usr/lib/libheimdal-asn1.dylib
0x7fff8fc77000 - 0x7fff8fcd6fff com.apple.framework.CoreWLAN (4.3.2 - 432.47) <AE6FAE44-918C-301C-A0AA-C65CAB6B5668> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8fd3a000 - 0x7fff8fd4afff libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
0x7fff8fd4b000 - 0x7fff8fd4bfff com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8fd4c000 - 0x7fff8fd85ff7 com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8fd86000 - 0x7fff8fdaafff libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib
0x7fff8fdab000 - 0x7fff8fdadfff libRadiance.dylib (1042) <B91D4B97-7BF3-3285-BCB7-4948BAAC23EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8fe2c000 - 0x7fff8fe5cfff com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8fe5d000 - 0x7fff8fe5dfff com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff8ff5a000 - 0x7fff90023fff com.apple.LaunchServices (572.26 - 572.26) <EF8A4A15-0861-35C5-9744-5E1BC5C26DD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff90281000 - 0x7fff90282fff libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
0x7fff90331000 - 0x7fff90332ff7 libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff90333000 - 0x7fff906aaffa com.apple.JavaScriptCore (9537 - 9537.74.4) <0942FE6B-3152-30FC-B92A-92A1C29C5295> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff906ab000 - 0x7fff906bdff7 com.apple.MultitouchSupport.framework (245.13 - 245.13) <D5E7416D-45AB-3690-86C6-CC4B5FCEA2D2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff906be000 - 0x7fff90724fff com.apple.framework.CoreWiFi (2.0 - 200.21.1) <5491896D-78C5-30B6-96E9-D8DDECF3BE73> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff90725000 - 0x7fff9097eff9 com.apple.security (7.0 - 55471.14) <3F7100A0-FE46-333D-9A4B-396580F1B4FE> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff90bd8000 - 0x7fff90bddff7 libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
0x7fff90bde000 - 0x7fff90be6ff7 com.apple.AppleSRP (5.0 - 1) <ABC7F088-1FD5-3768-B9F3-847F355E90B3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff9134c000 - 0x7fff9134ffff com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff913dd000 - 0x7fff913eafff com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff91429000 - 0x7fff9146bff7 libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
0x7fff9149e000 - 0x7fff91748ff5 com.apple.HIToolbox (2.1 - 697.4) <DF5635DD-C255-3A8E-8B49-F6D2FB61FF95> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff91749000 - 0x7fff91764ff7 libPng.dylib (1042) <36FF1DDA-9804-33C5-802E-3FCA9879F0E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff919ef000 - 0x7fff91a09fff libdispatch.dylib (339.90.1) <F3CBFE1B-FCE8-3F33-A53D-9092AB382DBB> /usr/lib/system/libdispatch.dylib
0x7fff91a0a000 - 0x7fff91a0bfff com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff91a0c000 - 0x7fff91b3bfef com.apple.MediaControlSender (2.0 - 200.34.4) <FC24EC8D-2E46-3F76-AF63-749F30857B96> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x7fff91b3c000 - 0x7fff91c20fff com.apple.coreui (2.1 - 231) <432DB40C-6B7E-39C8-9FB5-B95917930056> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff91c5d000 - 0x7fff91c89fff com.apple.CoreServicesInternal (184.9 - 184.9) <4DEA54F9-81D6-3EDB-AA3C-1F9C497B3379> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff91c8a000 - 0x7fff9206bffe libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff922b3000 - 0x7fff922faff7 libcups.2.dylib (372.2) <37802F24-BCC2-3721-8E12-82B29B61B2AA> /usr/lib/libcups.2.dylib
0x7fff9230e000 - 0x7fff9230efff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff9230f000 - 0x7fff92310ff7 libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
0x7fff923f1000 - 0x7fff92416ff7 com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff92467000 - 0x7fff92471ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff924e6000 - 0x7fff924e9fff com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff92503000 - 0x7fff92a73fff com.apple.CoreAUC (6.22.08 - 6.22.08) <F306D552-2220-3160-88EA-C916193C5EFD> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff92ad1000 - 0x7fff92ae4ff7 com.apple.AppContainer (3.0 - 1) <BD342039-430E-39FE-BC2D-8F97B557548E> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff92ae5000 - 0x7fff92aeafff libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
0x7fff92aeb000 - 0x7fff92b14ff7 libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib
0x7fff92b15000 - 0x7fff92b50fff com.apple.bom (14.0 - 193.1) <EF24A562-6D3C-379E-8B9B-FAE0E4A0EF7C> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff92b51000 - 0x7fff92b63fff com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff92bbc000 - 0x7fff92bc9ff0 libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
0x7fff92bdc000 - 0x7fff92be9ff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
0x7fff92bea000 - 0x7fff92c19fff com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff92c1a000 - 0x7fff92c75ffb com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff92c76000 - 0x7fff92ed7fff com.apple.imageKit (2.5 - 774) <AACDE16E-ED9F-3B3F-A792-69BA1942753B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff92ed8000 - 0x7fff92ee4ff7 com.apple.OpenDirectory (10.9 - 173.90.1) <E5EF8E1A-7214-36D0-AF0D-8D030DF6C2FC> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff930a4000 - 0x7fff930a4fff com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff930b3000 - 0x7fff930f8ffe com.apple.HIServices (1.22 - 467.2) <B7FCF008-C241-3862-BC63-E6EF4006A6E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff930f9000 - 0x7fff93194fff com.apple.PDFKit (2.9.1 - 2.9.1) <F4DFF4F2-6DA3-3B1B-823E-D9ED271A1522> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff93195000 - 0x7fff931a1ff3 com.apple.AppleFSCompression (56 - 1.0) <5652B0D0-EB08-381F-B23A-6DCF96991FB5> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff931d8000 - 0x7fff931dbff7 libdyld.dylib (239.4) <CF03004F-58E4-3BB6-B3FD-BE4E05F128A0> /usr/lib/system/libdyld.dylib
0x7fff933cd000 - 0x7fff933cffff com.apple.SecCodeWrapper (3.0 - 1) <DE7CA981-2B8B-34AC-845D-06D5C8F10441> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff93401000 - 0x7fff9346efff com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff9347c000 - 0x7fff9374cffc com.apple.CoreImage (9.2.7) <BF88A02E-994E-3970-AC62-04248CA8DC46> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff93884000 - 0x7fff938d1fff com.apple.AppleVAFramework (5.0.27 - 5.0.27) <D01B7D87-4BDC-3E48-A79B-951D05075F9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff93cb5000 - 0x7fff93cb5fff com.apple.Carbon (154 - 157) <45A9A40A-78FF-3EA0-8FAB-A4F81052FA55> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff93cfd000 - 0x7fff93d08fff libkxld.dylib (2422.90.20) <EF476345-7A69-3AC0-95ED-0196FB8910CB> /usr/lib/system/libkxld.dylib
0x7fff93dc9000 - 0x7fff93deeff7 com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff93def000 - 0x7fff93e53fff com.apple.datadetectorscore (5.0 - 354.3) <B92E87D1-2045-3AB2-AE3F-8F948B30518A> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff93e54000 - 0x7fff93e54ff7 libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
0x7fff93e55000 - 0x7fff93e84ff5 com.apple.GSS (4.0 - 2.0) <62046C17-5D09-346C-B08E-A664DBC18411> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff93e8f000 - 0x7fff93ef2ff7 com.apple.SystemConfiguration (1.13 - 1.13) <63B985ED-E7E4-3095-8D12-63C9F1DB0F3D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff93f02000 - 0x7fff93f06ff7 libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
0x7fff942f0000 - 0x7fff942fdff4 com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
0x7fff942fe000 - 0x7fff94356ff7 com.apple.Symbolication (1.4 - 129) <16D42516-7B5E-357C-898A-FAA9EE7642B3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 96958
thread_create: 1
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=206.7M resident=91.3M(44%) swapped_out_or_unallocated=115.4M(56%)
Writable regions: Total=98.4M written=1424K(1%) resident=1856K(2%) swapped_out=0K(0%) unallocated=96.5M(98%)
REGION TYPE VIRTUAL
CG shared images 140K
Kernel Alloc Once 4K
MALLOC 87.4M
MALLOC (admin) 32K
STACK GUARD 56.0M
Stack 9824K
VM_ALLOCATE 348K
__DATA 25.8M
__IMAGE 528K
__LINKEDIT 65.7M
__TEXT 141.1M
__UNICODE 544K
mapped file 25.8M
shared memory 4K
TOTAL 412.9M
