I have a wierd problem. everything is ok in Preview Mode but when I Publish the file external swf will not load in main swf.
I didnt change the location of main file and swf file are locally available. SO i have no idea what is the problem.
Is it related to AS3 setting or something ?
what are you publishing? web-based, ios, android, air, projector app?
"swf" with flash cc
it is not a network project just locally will be used . and "access local files" is chosen..
what's the code in the main swf used to load?
what's the location (relative to the main swf) of the loaded swf?
is there any code that would cause the loaded swf to be unloaded or no longer seen?
// loading external swf
// We'll store our buttons in an array to make it easier to register for events.
var btns:Array = [
btn_octapus,
btn_shark,
btn_dolphin
// Now cycle over them in bind to our listener
for each (var btn:MovieClip in btns) {
btn.addEventListener("mouseUp", btnEvents);
function btnEvents(e:MouseEvent):void {
// With one event listener, we can sort out each condition
switch (e.currentTarget.name) {
case "btn_octapus":
loadGame("001.swf")
break;
case "btn_shark":
loadGame("002.swf")
break;
case "btn_dolphin":
loadGame("0013.swf")
break;
function loadGame(url:String):void {
// Now we only have to write our loader code once (for all buttons)
trace("Loading " + url);
// Because we're unloading our swfs (and unloaded assets get garbage collected),
// we'll want to make a new loader each time we call a load op
var loader:Loader = new Loader();
loader.name = "current_game";
loader.load(new URLRequest(url));
addChild(loader);
loader.x=100;
loader.y=100;
I just added external swf to main folder for test..
It works for preview in flash correctly but after Publishing, No external swf will be loaded.
that's problematic if you intend to reference any loaders and you failed to answer the 2nd and 3rd questions.
2nd Question:In the main folder where the FLA file is.
3rd Question : No
In Preview Mode it works fine but only when I publish the fla I have problem with that...
no? then why do you have this comment
and why are you using different loaders and why are you making them local to loadGame?
unless you have reasons for the above and know what you're doing, change your loadGame code to:
var loader:Loader=new Loader();
addChild(loader);
loader.x=100;
loader.y=100;
I want to use 1 loader for all external swf. there are 13 swf that i want to load. there is 13 button for every swf.
and I want when one external swf are loaded , others should be unloaded(to reduce memory use and cpu&...)
So whats your suggestion ?
we have 13 btn and 13 swf .
buttons named differently
btn_octapus
btn_shark
but swf are in sequence of 001.swf to 0013.swf
then use the code i suggested in message 7.
though, if there are open streams (video/sound etc) in a loaded swf, use:
addChild(loader);
loader.x=100;
loader.y=100;
if(loader.content){
loader.unloadAndStop();
thank you.
but still I have Problem with the external swf...
By the way , Is there any protected swf ?
you know , I create slideshow with program named "UltraSlideshow" and I can not load them.Can it be the problem or not ?
what swf is failing to load?
swfs that I created as an slide show ... they are not loading in main SWF. but in preview mode they load but not in Published. .
what are the problematic swf names?
001.swf
002.swf
0013.swf
what's the url to your main swf's embedding html?
it is a local project and I need to make a .exe or at least swf. not html version...
