JenLarkin
Help! Can't install
Jun 11, 2007 2:05 AM
error message: "please select another location to extract the installer to:" no matter what directory I select when I hit "choose" the error persists. I can not get past this error message no matter where I choose to extract. I a unable to install.
I currently have Flex Builder 2.0 with charting installed on my windows xp machine. I am unable to find the 2.0.1 updater via the Flex Builder 2's update system. There is no option for Adobe that came installed.
I assume that the answer that I will get will be that I have to upgrade to 2.0.1 but that really doesn't help if I can't figure out how!
    Community Member
    Jun 11, 2007 6:56 AM
    Did you try all of the sanity checks? Enough disk space (with some to spare). Try a directory without spaces in it? Reboot? :)
    Community Member
    Jun 11, 2007 3:41 PM
    I've experienced the same problem, and it's my belief that it's down to errors in unpacking the installation files to a temp directory and the message is just unhelpful. I consistantly get it when trying to install from the install file stored on a fat32 usb stick, copying the file from there to the local drive does not help either. However, copying the file from from it's original download location via a network share to the local drive and running it from there did result in a success for me.
    Totally unscientifically and unproven, I'd try avoiding fat filesystems, download or copy the installer to your local drive, and make sure you have *plenty* of spare space in your temp directory. I suspect somehow my file got corrupted slightly, but can't really tell, I've had similar problems before with recent adobe installers. a checksum would be handy, if you guys at adobe are reading!
    Sorry I can't be more definitive, but hope that helps you. Bear in mind I may be wrong.
    Jim.
    Community Member
    Jun 11, 2007 5:00 PM
    It could be that the installer checksum is failing, but all it outputs is "please select another location to extract the installer to:" whenever it fails (for whatever reason) ?
    pure speculation, of course, but I've done far worse in my own installers ;)
    I should mention that i also had cleared my temp directory inbetween failed and succesful install, in case it does have any bearing.
    Jim.
    Community Member
    Jun 12, 2007 10:47 AM
    Were you ever able to install? Please let me know.
    Bill
Legend
  • Correct Answers - 10 points
  • Helpful Answers - 5 points
