I've made a image loader using this code below, if I want this card clickable when its compile, what I suppose to do? please..
var kartu = new card();
var a:int = 0;
var counter:int = 0;
while (a<11)
getImage(kartu.player, counter, a);
a = a + 1;
counter=counter+65;
function getImage(name, counter, ac)
var url:URLRequest = new URLRequest("dekKartu/" + name + ".png");
var loader:Loader = new Loader();
loader.x = counter;
loader.y = 560;
loader.load(url);
addChild(loader);
You should never nest named functions. Pull the test function out on its own.
YOu could be targeting anything by blindly targeting just " x "... it sounds like it is targeting whatever holds all the cards which would explain why they all move. Try changing the test function to be...
function test(evt:MouseEvent):void
MovieClip(evt.currentTarget).x += 5;
One option is to just add an event listener to the loader....
loader.addEventListener(MouseEvent.CLICK, doSomething);
but Ned, if I use that code, then all of cards that loaded will move..
I wish I can make each card clickable so I can do something for each card
anyone? please..
Why will adding an event listener cause anything to move?
hahaha sorry I forgot..
I tested "doSomething" with move function, like x = 5. when I run and I click, all of items on screen move, and I can click anywhere..
let me show you, lets say this boxes as cards.
before :
hello world
after run :
hello world
how if I just want make 1 card clickable..
like card game, click 1 card to throw 1 card, click deck to get 1 card to hand
I don't see how any of the code you have shown will move anything, and adding the event listener I indicated will not either. Show the full code for the doSomething function you wrote. If written properly it should only affect things relative to the button clicked.
I sent you the source to message
Please keep all information in your posting
// I put this on frame
var a:int = 0;
var counter:int = 325;
while (a<11)
a = a + 1;
counter=counter+65;
loader.x = counter;
loader.y = 560;
loader.load(url);
addChild(loader);
and I use this on .as file
import flash.events.*;
import flash.net.URLRequest;
import flash.display.Loader;
public class card {
var cardArr:Array = ["A1","A2","A3","B1","B2","B3","C1","C2","C3","D1","D2","D3","E1","E2 ","E3","F1","F2","F3","G1","G2","G3","H1","H2","H3","I1","I2","I3","I4 ","I5","I6",
"A1","A2","A3","B1","B2","B3","C1","C2","C3","D1","D2","D3","E1","E2" ,"E3","F1","F2","F3","G1","G2","G3","H1","H2","H3","I1","I2","I3","I4" ,"I5","I6",
"A1","A2","A3","B1","B2","B3","C1","C2","C3","D1","D2","D3","E1","E2" ,"E3","F1","F2","F3","G1","G2","G3","H1","H2","H3","I1","I2","I3","I4" ,"I5","I6"]
public var player:Array = new Array(11);
public var com1:Array = new Array(11);
public var com2:Array = new Array(11);
public var com3:Array = new Array(11);
public var deck:Array = new Array(136);
public function card() {
var koa_card:Array = generate_deck();
var a:int = 0;
var index_counter:int = 0;
while(a < 180) {
if(a < 11) {
player[index_counter] = koa_card;
if(a >= 11 && a < 22) {
com1[index_counter] = koa_card;
if(a >= 22 && a < 33) {
com2[index_counter] = koa_card;
if(a >= 33 && a < 44) {
com3[index_counter] = koa_card;
if(a >= 44) {
deck[index_counter] = koa_card;
a = a + 1;
index_counter = index_counter + 1;
if(index_counter > 10 && a < 45){
index_counter= 0;
function generate_deck() {
var shfArr:Array = new Array(180);
shfArr = kocok(cardArr);
return shfArr;
function kocok(array) {
var m = array.length, t, i;
while (m) {
i = Math.floor(Math.random() * m--);
t = array
array
array = t;
return array;
please..
I do not see anything relative to the event listener I said to add nor the "doSomething" function you say causes everything to move.
var a:int = 0;
while (a<11)
a = a + 1;
counter=counter+65;
loader.x = counter;
loader.y = 560;
loader.load(url);
addChild(loader);
loader.addEventListener(MouseEvent.CLICK, test);
x += 5;
sorry I forgot I have deleted it, because I just test that "test" function
I see I see..
thanks a lot Ned
You're welcome
