Hi Guys,
I really need you help.
I am building an iOS app with adobe air 3.8. And testing it on Iphone 5, iOS 7
Im playing a mp4 with stageVideo and everything works fine apart from the fact the every second/third time or so that I open the app and plat the video the app crashes without any warning!
Please.....Can any one help ?
Here is the simple code that I use:
Thanx in advance
/Henry
import flash.net.NetStream;
import flash.net.NetConnection;
var netStream:NetStream;
var netConnection:NetConnection;
var video:Video;
netConnection = new NetConnection();
netConnection.connect(null);
netStream = new NetStream(netConnection);
netStream.client = new Object();
video = new Video(320,240);
video.attachNetStream(netStream); // might be overridden later
// Set up normal display list properties
video.x = 100;
video.y = 100;
video.width = 320;
video.height = 240;
addChild(video);
netStream.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
// Try to render as stage video
var v:Vector.<StageVideo> = stage.stageVideos;
if ( v.length >= 1 ) {
var stageVideo:StageVideo = v[0];
stageVideo.viewPort =
new Rectangle(100,100,320,240);
stageVideo.addEventListener(
StageVideoEvent.RENDER_STATE,renderStateEventHandler);
stageVideo.attachNetStream(netStream);
netStream.play("filmtest_1.mp4");
function renderStateEventHandler(event:StageVideoEvent):void
// If video is not rendered properly let the
// video object in the display list try to render it.
if ( event.status == StageVideoEvent.RENDER_STATUS_UNAVAILABLE ) {
function asyncErrorHandler(event:AsyncErrorEvent):void {
trace(event.text);
You won’t be allowed to submit an AIR 3.8 based app to the App Store, so you ought to change over to using the current version of AIR, which is AIR 13. There may well have been StageVideo fixes in AIR 3.9, 4.0, or 13, so it’s worth giving it a try.
Hi Colin,
Thank you very much for your advice
I updated to SDK 13 and it seems to have fixed the problem.
Thanx again..Greatly appriciated
Best
Henry
