GmR
Flash CS3 Professional Very Slow & Sluggish
Aug 5, 2007 8:24 PM
I recently upgraded to Flash CS3 Pro (WinXP). It is very slow to use -- the mouse keeps getting "stuck" for several seconds at a time, sometimes longer. It seems to get even slower when I open the script window (F9).
Has anyone else had this problem, and is there a way to fix it? It sort of drives you insane.
Geoff
    Aug 5, 2007 11:18 PM   in reply to GmR
    How much RAM do you use? are you sure your machine meets the requirements of Flash CS3?
    Aug 5, 2007 11:40 PM   in reply to GmR
    this problem happened with me when I open a very heavy file or if there is some thing eats my RAM. try to test the Flash while just opening a new file and make sure you do not have some thing or software eats your RAM.
    Aug 6, 2007 9:05 AM   in reply to GmR
    I have a similar problem -- the scripting window drags incredibly slowly on my 2.08 GHz desktop, but runs perfectly smooth on my 1.8 GHz laptop. They both have 1 GB ram. No other programs run as slow as CS3 does, even without any documents open!
    Aug 6, 2007 9:16 AM   in reply to RavenWorks
    are you using Mac?
    Have a look Here. It might not give solution, but you're not alone.
    Aug 6, 2007 9:45 AM   in reply to GmR
    Nope, my desktop and laptop are both PCs running Windows XP. GmR mentioned in his post that he uses WinXP too.
    Aug 15, 2007 7:04 PM   in reply to GmR
    You certainly are not alone. I'm running into the same problem. I have 4gb of ram in my system, though I'm not running vista yet, thus it sees 2.5gb. I'm on a dual dual-core xeon 3.0g system, so it actually exceeds the recommendations for HD video. I have a 5 disc raid0 array.
    I don't have any answers for you, nor do I have any new information. But I do want to confirm that there is a big problem. My ram appears unused, and so do my CPUs. The CPUs get used for 10 seconds, then sit for 45... it's entirely useless.
    Is there anything that can be done? It's really, really useless to have your computer freeze 2/3 of the time while a program is simply open and doing nothing...
    Aug 15, 2007 9:22 PM   in reply to GmR
    Let me clarify -- my problem is entirely and only with the Flash Video Encoder.
    Aug 15, 2007 10:45 PM   in reply to CityOfRain
    Do you mean this problem only happen when you import video into Flash? how large is the video you are trying to import?
    Aug 16, 2007 1:01 AM   in reply to GmR
    Hello Rafiq,
    At any time I put an mp4 video in the encoder, even files of just 3 minutes long, and 45 MB big, it goes to a "not responding" situation, stealing my pointer, and sitting on something. All I get is a hung computer. I have to wait a long time before I can control anything. This occurs with small or large files, mp4 and avi. This does not happen in Handbrake.
    This does not just happen on import, but during the encoding process as well. It takes lots more time than it did with the prior encoder.
    Aug 20, 2007 12:59 PM   in reply to GmR
    Anyone have any thoughts??
    Aug 20, 2007 10:24 PM   in reply to CityOfRain
    may be try to reinstall Flash, I do not know if you did that already. Also i suggest to do the same process on a different machine with different Flash version, if the problem in your Flash version, you will need to contact the Customer support
    Aug 21, 2007 4:20 AM   in reply to GmR
    This is scaring me off from upgrading to CS3. Have you officially reported this as a bug? Now that this is Adobe's first real release of Flash, HOPEFULLY they will break from Macromedia's tradition of never fixing bugs. The bug report form is here:
    http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    I encourage everyone experiencing this issue to report it. The more reports, the more chance Adobe might listen.
    Aug 22, 2007 10:26 PM   in reply to GmR
    If they aren't looking at their own forum, I'd be shocked
