> I am using a table to make a LONG page on my website
known issue:
http://kb.adobe.com/selfservice/viewContent.do?externalId=54f19ec2&sli ceId=2
or
http://www.adobe.com/go/54f19ec2
"Dreamweaver 8 does not fully render large files in Design
view on Macintosh
Issue
When you open certain large files in Design view in
Dreamweaver 8 on the
Macintosh, Dreamweaver does not render the complete page.
This typically
causes the last section of the page to be cut off. This issue
does not occur
in earlier versions of Dreamweaver.
The size limit is not the number of bytes in the source file,
but the
display size to which the markup renders. Dreamweaver 8
currently has a
limitation of 32,768 pixels by 32,768 pixels on the
Macintosh. (Ref. 201845)
Solution
The Dreamweaver engineering team is researching this issue.
Below, find two
workarounds for this issue:
* Change the Set Magnification pop-up menu in the lower
right corner of
the Document window to 99% or 101%. You can type these values
directly into
the Set Magnification pop-up menu.
* If possible, break your page into smaller pieces over
multiple files.
TechNote Details
Last Update: 09-19-2006
OS:
* Macintosh-All
Permanent Link:
Alan
Adobe Community Expert, dreamweaver
http://www.adobe.com/communities/experts/
