Cluster nodes discover peers outside cluster domain
Aug 7, 2007 1:59 PM
All, cross-posted from the ColdFusion Server Administration forum:
I've run into an issue with CFMX7 clustering on a subnet with multicast disabled. In our configuration, we have two physical Windows Server 2003 Enterprise Edition servers hosting nine ColdFusion MX 7 Enterprise clusters. Each server hosts one of two instances in a cluster. i.e.:
server1 [1.2.3.4] - instance1-1 <- cluster1 -> server2 [1.2.3.5] - instance1-2
server1 [1.2.3.4] - instance2-1 <- cluster2 -> server2 [1.2.3.5] - instance2-2
server1 [1.2.3.4] - instance3-1 <- cluster3 -> server2 [1.2.3.5] - instance3-2
server1 [1.2.3.4] - instance4-1 <- cluster4 -> server2 [1.2.3.5] - instance4-2
server1 [1.2.3.4] - instance5-1 <- cluster5 -> server2 [1.2.3.5] - instance5-2
server1 [1.2.3.4] - instance6-1 <- cluster6 -> server2 [1.2.3.5] - instance6-2
server1 [1.2.3.4] - instance7-1 <- cluster7 -> server2 [1.2.3.5] - instance7-2
server1 [1.2.3.4] - instance8-1 <- cluster8 -> server2 [1.2.3.5] - instance8-2
server1 [1.2.3.4] - instance9-1 <- cluster9 -> server2 [1.2.3.5] - instance9-2
My first step in enabling peer discovery was to add the unicastPeer attribute to the ClusterManager service under each instance.
e.g. jrun.xml on instance1-1:
<service class="jrunx.cluster.ClusterManager" name="ClusterManager">
<attribute name="bindToJNDI">true</attribute>
<attribute name="enabled">true</attribute>
<attribute name="clusterDomain">cluster1</attribute>
<!-- While we will discover nearby peers automatically without prior knowledge -->
<!-- of them, you can also add as many specific hosts as you wish; these unicast -->
<!-- peers do not need to be nearby or reachable via multicast. -->
<!--EXAMPLE: <attribute name="unicastPeer">sneville</attribute> -->
<attribute name="unicastPeer">1.2.3.5</attribute>
<service class="jrunx.cluster.ClusterDeployerService" name="ClusterDeployerService">
<attribute name="deployDirectory">{jrun.server.rootdir}/SERVER-INF/cluster</attr ibute>
<attribute name="deactivated">false</attribute>
</service>
</service>
e.g. jrun.xml on instance1-2:
<attribute name="unicastPeer">1.2.3.4</attribute>
</service>
</service>
. . . and so on for each instance and cluster. This is where the problem begins. When I start the instances, every instance discovers every other instance as a cluster peer, regardless of cluster domain.
Another forum user suggested using host:port, where port is the JNDI listening port. That doesn't work. Using the Jini listening port, however, does work, e.g.:
<attribute name="unicastPeer">1.2.3.4:4160</attribute>
That presents another problem. The Jini listening port defaults to 4160. If 4160 is taken, a port is chosen at random.
I can't find documentation on setting a static Jini listening port, if that's even the correct action to take.
Thoughts?
From what I can tell, the version of Reggie (the Jini lookup service) shipped with JRun only supports setting the unicast listening port programmatically. Reggie is started by jrunx.cluster.ClusterManager.init--actually, the private method startLookupService--and JRun doesn't appear to ever call Reggie's setUnicastPeer method.
Assuming we can't tweak Reggie, I guess a more appropriate question is how do we get JRun's RMI service (?) to honor groups/domains in a call to getPeers? I'll cross-post to the JRun forums and investigate JRun Updater 6.
Trev
    Aug 21, 2007 4:24 PM   in reply to TRS-80
    Jrun uses and empty group name I believe TRS
