RegExp multiline
Oct 1, 2007 5:25 AM
Can anyone make RegExp multiline work ? So far I've been replacing \n and \r with <cr> to flatten the string, then switching back the CRs.
var re = new RegExp("(.*)<!-- OrdinarySiteMap -->.*<!-- OrdinarySiteMap -->(.*)","m");
RegExp.multiline = true;
re.multiline = true;
var Slurp = re.exec(ExistOSMfile);
if (Slurp) {
var Topper = Slurp[1] + '<!-- OrdinarySiteMap -->';
var Bottomer = '<!-- OrdinarySiteMap -->' + Slurp[2];
    Oct 1, 2007 10:36 AM   in reply to meshgraphics
    meshgraphics,
    Most people assume that the . wildcard means "match everything", but it
    actually means "match eveything except \r and \n". Use (.\r\n) instead.
    Another tip: most people also assume that * means match *first* (i.e.
    smallest) match, but it actually means match *largest* match. This can
    lead to undesired results and unnecessary performance penalty
    (especially when searching across multiple lines). Use .*? or (.\r\n)*?
    for minimum match.
    HTH,
    Randy
    > -->(.*)","m");
    > if (Slurp) {
    Oct 2, 2007 11:11 AM   in reply to Newsgroup_User
    > Ok Randy.
    Ok, mr. anonymous.
    > Do most people know how multiline RegExp works?
    No. I've answered this question many times.
    > I don't see any evidence that you do.
    You didn't even try what I said. Excuse me for answering off the top of
    my head and getting the syntax slightly wrong, it should be this:
    (.|\n|\r)*?
    Oct 2, 2007 11:35 AM   in reply to Newsgroup_User
    What I think is missing in DW is a "multiline" checkbox on the Search &
    Replace GUI. With this checked DW should let "." match newlines as well,
    just like the "\m" modifier does.
    After all, we have a "Match case" checkbox that works like "\i". Since DW
    doesn't allows modifiers inside the RegExp itself, all the available
    modifiers should be exposed by the GUI.
    As an alternative DW should understand modifiers that are entered inside the
    GUI (either \i, \m or whatever the engine supports).
    As it stands, it's not obvious at all for anybody who is familiar with
    RegExp. Using (.|\n|\r)*? is just a counterintuitive workaround.
    I asked for this features many times in the past. But I gave up a few years
    ago...
    Massimo Foti, web-programmer for hire
    Tools for ColdFusion and Dreamweaver developers:
    http://www.massimocorner.com
    Oct 2, 2007 1:28 PM   in reply to Newsgroup_User
    Hi Massimo,
    Good to see you here!
    It looked like the original poster was having problems in the code, so I
    didn't even mention the UI :)
    DW always does a multi-line search in the Search & Replace now (in CS3,
    anyway -- can't remember which version we changed that). Of course, it
    doesn't work if you use . for the reasons that I have already explained.
    So, I'll mark your feature request as "fixed" :)
    Randy
    > ago...
    Oct 2, 2007 1:52 PM   in reply to Newsgroup_User
    "Randy Edmunds" <redmunds_nospam@adobe.com> wrote in message
    news:fdu9lj$dor$1@forums.macromedia.com...
    Sorry Randy, but I don't think I explained my request well enough.
    Modern RegExp engines supports modifiers:
    http://www.regular-expressions.info/modifiers.html
    DW doesn't supports modifiers inside the pattern. Most likely this choice
    was made to make life easier for people who don't know RegExp too well (most
    users out there). Instead there is a checkbox that mimic the way the /i
    modifier works.
    What's missing is something that let you switch between /s and /m.
    You either provide GUI equivalents for all the modifiers supported by the
    RegExp engines or let advanced users add modifiers inside the pattern
    itself.
    So yes, DW always does a multi-line search, but I want a way to turn it into
    "single-line mode", where "dot" matches new lines too. See below (please
    note it's very easy to mix up the terms):
    http://www.regular-expressions.info/dot.html
    Massimo
    Oct 2, 2007 9:16 PM   in reply to meshgraphics
    meshgraphics wrote:
    > Attn: Tourists
    > This newsgroup is for people who have actually written a DW extension, not
    > feature requests for newbies.
    Massimo has written quite a few extensions, and Randy is one of the engineers that works on Dreamweaver, so it might be worth backing off a bit with the attitude if you intend to get help from folks.
    > The RexExp features listed at regularexpression.com do not matter when you are
    > trying to troubleshoot your DW extension. What matters is: what actually works
    > in the DW extension environment.
    They do to a certain extent, as they refer to the use of regular expressions within JavaScript, which Dreamweaver does use in extensions. Note this page:
    http://www.regular-expressions.info/javascript.html
    It states:
    /m enables "multi-line mode". In this mode, the caret and dollar match before and after newlines in the subject string.
    It also states:
    Notably absent is an option to make the dot match line break characters.
    Based upon both of these statement, the RegExp you present below does not do what you want it to do in JavaScript, regardless of Dreamweaver's involvement or not. The m flag does not allow the . character to match new lines in JavaScript and so you won't get from the beginning of the input string, rather you'll get from the beginning of the line that MARKER happens to be on.
    > The purpose of the original questions and code snippet was to grab the top
    > portion of a file, up to the marker, in its original format, so that it could
    > be written as is, to the output file. According to old js, something like this
    > would work:
    > Slurp = /(^.*)MARKER(.*?)/m.exec(MultilineInputString);
    > write(Slurp[1]); // <html><head><body>
    > write(Slurp[2]); // </body></html>
    What "old js" are you referring to that says that this should work the way you are saying it should?
    For this code:
    <html>
    <head>
    <title>My Document</title>
    </head>
    <body>
    MARKER
    </body>
    </html>
    This RegExp grabs the content from the beginning of the code before MARKER, and also the content after MARKER through the end of the code:
    /^((?:.|\r|\n)*)MARKER((?:.|\r|\n)*)$/
    Danilo Celic
    | Extending Knowledge Daily : http://CommunityMX.com/
    | Adobe Community Expert
    Oct 3, 2007 9:17 AM   in reply to Newsgroup_User
    Ah. As you know, DW uses the Netscape JavaScript engine. We have the
    JavaScript source code and have made tweaks in the past, but they end up
    being a maintenance nightmare in the long run, so hopefully this will
    get fixed in JavaScript.
    > See below (please note it's very easy to mix up the terms):
    Yes, a slightly easier and more clear technique to match everything in
    JavaScript regular expressions is to use 2 opposing terms such as
    [\s\S]. This matches all characters which are either whitespace or not
    whitespace.
    Randy Edmunds
    Dreamweaver Engineering
    Adobe Systems, Inc.
    Oct 3, 2007 9:53 AM   in reply to meshgraphics
    And based on Randy's latest post this Regular Expression also works:
    /^([\s\S]*)MARKER([\s\S]*)$/
    Goes to show there are many ways to handle doing regular expressions, and you can always learn a new way to do the same thing.
    Danilo Celic
