Hi all, I'm trying to import RSS into my database for this I
created an XSLT
stylesheet that transforms the XML into a series of SQL
statements like
below
INSERT INTO rss_feed(feed_title,feed_link,feed_description)
VALUES('','
http://...','');
SELECT @feed_id := MAX(feed_id) FROM rss_feed;
INSERT INTO
rss_channel(feed_id,channel_title,channel_link,channel_description,ch annel_language,channel_copyright,channel_managingeditor,channel_webmas ter,channel_pubdate,channel_lastbuilddate,channel_generator,channel_do cs,channel_cloud,channel_ttl,channel_image,channel_rating,channel_skip hours,channel_skipdays)
VALUES(@feed_id,'...','...','','','','','','','','','','','','','','', '');
SELECT @channel_id := MAX(channel_id) FROM rss_channel;
INSERT INTO
rss_item(channel_id,item_title,item_link,item_description,item_author ,item_comments,item_guid,item_pubdate)
VALUES(@channel_id,'...','','...','Joris van Lier','','','');
SELECT @item_id := MAX(item_id) FROM rss_item;
INSERT INTO
rss_enclosure(item_id,enclosure_url,enclosure_type,enclosure_length)
VALUES(@item_id,'
http://...','...','...');
My problem is: I can pipe this into a command-line sql
session but when
executing it from PHP it gives me a sql syntax error, running
the statements
separately does not preserve the needed context with the
foreign key
variables.
Second problem: how do I select the last inserted id in
MySQL; is there an
equivalent to @@IDENTITY?
mysql Ver 14.7 Distrib 4.1.13, for unknown-linux-gnu (x86_64)
using
readline 4.3
Joris van Lier
