HTTPService in ActionScript
Nov 16, 2007 9:27 AM
I've created this class
quote:
package services
import mx.collections.ArrayCollection;
import mx.rpc.http.HTTPService;
import mx.rpc.events.FaultEvent;
import mx.rpc.events.ResultEvent;
public class RSSService implements IService
private var _feeds:ArrayCollection;
private var _titleChannel:String;
private var _rssService:HTTPService;
public function RSSService(url:String) {
_rssService= new HTTPService();
_rssService.url= url;
_rssService.useProxy= false;
public function send():void {
_rssService.send();
_rssService.addEventListener(ResultEvent.RESULT, resultHandler);
_rssService.addEventListener(FaultEvent.FAULT, faultHandler);
private function resultHandler(event:ResultEvent):void {
_feeds= event.result.rss.channel.item;
_titleChannel= event.result.rss.channel.title;
private function faultHandler(event:FaultEvent):void {
public function getResult():Object {
if (_feeds == null) _rssService.send();
var result:Object= new Object();
result.feeds= _feeds;
result.titleChannel= _titleChannel;
return result;
and i use it in this way
quote:
[Bindable]
public var feed:ArrayCollection;
[Bindable]
public var titleChannel:String;
private function onConfirm():void {
var service:RSSService= new RSSService(rssUrl.selectedItem.data);
var obj:Object= service.getResult();
titleChannel= obj.titleChannel;
feed= obj.feeds;
currentState= 'reader';
in the Application file.
When i launch the application, the HTTPService object doesn't call resultHandler(event:ResultEvent) method, so the _feeds Array is empty.
Why?
I need tutorials, where i can found they?
Byr
    Nov 19, 2007 2:33 AM   in reply to PremierITA
    Are you sure your URL is getting called at all? What if you add some alert message in the fault hanlder?
    ATTA
    Nov 19, 2007 4:11 AM   in reply to PremierITA
    it seems ti should work. thing is...you do not call getResult() immediately before resultHandler fires. So, make sure resultHandler fires and then call getResult().
    KBala
    Nov 19, 2007 5:38 AM   in reply to PremierITA
    just dispatch an event in this function
    xxxxx your code xxxxx
    ********dispatch the event here**************
    and, capture the event where you use the class's instance.
    thanks
    KBala
    Nov 20, 2007 3:57 AM   in reply to PremierITA
    hi,
    i rewirte your code like this
    class
    package services
    import flash.events.EventDispatcher;
    import flash.events.Event;
    [Event(name="result",type="mx.rpc.events.ResultEvent")]
    public class RssService extends EventDispatcher
    public function RssService(url:String)
    super();
    _rssService.send();
    var evt:ResultEvent = new ResultEvent("result",false,true,result);
    dispatchEvent(evt);
    Implementation
    import services.RssService;
    import mx.core.SoundAsset;
    private var r:RssService;
    private function init():void
    r = new RssService("url here");
    r.addEventListener(ResultEvent.RESULT,resultHandler)
    r.send()
    // use event.result here
    this will be solve your issue, good luck!
    KBala
