quote:
Originally posted by: MikeBomb
I have been going crazy with this one too but I finally found a solution. Here it is:
Go to a page with a Flash video on it.
Click on the video to activate Flash, then right click on it to bring up the Flash menu.
Click on "Settings", then click the "Advanced..." button.
This should open a new browser window with the Flash Player Settings Manager.
Look on the left side, under "Table of Contents" and "Flash Player Help", for "Global Storage Settings Panel"
Click the "Global Storage Settings Panel" link. This will load the panel on the right side in a Flash object.
You will find that the "Allow third-party Flash content to store data on your computer" box is unchecked.
Check that box!!!
After the box is checked, it should save the setting right away, but I had a little trouble getting it to save the setting. I had to close all open Internet Explorer windows and go back and check the box several times, but finally it saved the setting. Once it did, I had audio in my embedded YouTube videos again.
Check that box!!!
Check that box!!!
quote:
Originally posted by: emcenroe
the Windows Registry Editor thing didn't work for me, but finally found something that did! i had no sound on any of my flash files (videos, music) and now everything is back in 100% working order. i know nothing about computers, but it had something to do with downloading a different codec pack (whatever that is!) and uninstalling an old one. just follow the directions--if i could do it, anyone can!
http://www.nosystemsounds.com/
GO TO THIS SITE and just follow the directions--hopefully you'll have your sound back in no time!
good luck and God bless!
emcenroe
quote:
Originally posted by: wcyee
Hi There,
Sorry to trouble you. Apprently, i got the same problem as you had (3rd party embedded video produced no sounds..but i did managed to get sounds from youtube though)...
Tried the reg fix...and everything under the sun..but did not work either...
Any more solutions?this is killing me...Thanks..
quote:
Originally posted by: play_
Here we are, more than a year later and still no fix.
I've tried everything:
-Uninstalling and installing flash player
- installing Adobe Flash
- K-lite code pack fix
- CCleaner
-Registry fix
-Sound settings check/fixes
**** just does not work. wtf adobe. buy out macromedia and then break their products... gg.
quote:
Originally posted by: BilalM
Alright the problem is really the mapping of wavemapper in Windows registry as reported by one member of the forum. All you need to do is to open registry editor by going to Start menu, Run, typing regedit and then Enter. After that, in the registry editor, walk yourself through the tree in the left pane, till you reach
My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32
And then on the right pane, right click and click on New, select String value, enter "wavemapper" (without quots of course), ENTER, type "msacm32.drv", ENTER.
Close the editor. No need to restart. Video on Google and YouTube et al would work fine now.
Thanks to the member who pointed out the key. I just mentioned the procedure.
Have a nice day!
quote:
Originally posted by: exurber
OK people - listen up. This is the fix for Windows and I suspect Mac and Linux too.
Make sure that your green speaker plug is stuck into the green hole. Don't plug it into the blue hole. That is the wrong hole.
Depending on your sound card or chipset, you should get a new device aquired option dialogue when you make penetration. Select the front panel (which turns into line out) or line out.
Line out is where system and browser sounds are sent.
Browsers, reg hacks, codecs make no difference. It is a hardware issue.
quote:
Originally posted by: nosoundguy
Unbelievable. So I have been having the problem since updating to Flash 9, and I guess I can somewhat understand why Adobe isn't too hot on addressing this problem considering it is my own damn fault. I tried everything in this forum "Softwarewise" that I could do, but the problem ended up being with my speaker ports. Here's the thing, I have 5.1 surround, and for some reason the way I had it configured before worked fine, but when I upgraded to flash 9 it became a problem. I didn't think to look at my speaker configuration because it worked before the upgrade. I figured out that the headphone port worked fine, I had sound on everything as long as I was using the headphones. Here's the funny part, I reconfigured my speakers and they didn't work STILL, and I couldn't figure out why, because it should be working fine. Meanwhile sound was still coming out of the headphones, frustrated I threw the headphones at the printer they came unplugged and I had sound in my front speakers! Ha, I am such an IDIOT! I forgot that the headphones cut off the front speakers when plugged in, anyway, everything works fine now. I also think that this is only a problem with people using the REALTEK 97 DRIVER, with Soundblaster Speakers, the colors don't exactly match up, and for A.D.D. idiots like me it's a problem. I hope that me being an idiot helps some other guy.
quote:
Originally posted by: mpburg
quote:
Originally posted by: DecepticoN510
I've been having the 'No sound in flash player' problem and I think I may have found a solution, at least it worked for me. I actually found this on another forum and the solution is for XP users I believe.
When I would check my sound and audio device properties, it actually said that I had no audio device. And for some odd reason, under the sound tab and voice tab all the devices were set to "Modem #1Line..." The dropdown menu in these fields did not allow for any other choice. So as per the other forum, I proceeded with:
Start > Control Panel > Administrative Tools > Services > Windows Audio. Make sure "Windows Audio" service is running. If it's not, right click on this service and select "start".
Then I went back to sound and audio device properties and switched all the "Modem #1 Line..." back to the proper device as it was now available in the dropdown menu. Now I have sound in youtube and any other flash related sites.
Hope this helps.
